For bus snooping, I would suggest using a microcontroller which, while watching the bus, will be devoting all its energy to that task; if any sort of interrupt response will be needed while the bus is being monitored, use a separate processor for the bus monitoring and the other tasks. The bus-monitoring processor could probably act as an SPI slave while it is monitoring the bus, if none of the things it is asked to do while monitoring the bus would be overly complicated [e.g. if the only thing the master ever wants it to do is say whether any interesting bus cycle has happened and, if so, what data was transferred then]. Note that the firmware for the bus-monitoring processor would likely have to be written in machine code and might look something like this:
MAIN_LOOP:
bl R12 ; Assume R12 holds address of bus-polling rou
ldrb r0,[r11,#SPI_REGS_OFS] ; Assume R11 always holds base of SPI peripheral
and r0,r0,#SPI_READY_FLAG
beq MAIN_LOOP
bl R12
ldrb r4,[r12,#SPI_DATA_REG]
and r0,r4,#15
ldr pc,[pc,r0,asl,#2]
nop
; Insert table of 15 jump addresses here
dc.w CMD00_HANDLER, CMD01_HANDLER, CMD02_HANDLER, ... etc.
CMD00_HANDLER:
bl R12
sub r0,r8,r9 ; Assume R8 and R9 are queue pointers
strb r0,[r12,#SPI_DATA_REG]
b MAIN_LOOP
CMD01_HANDLER:
bl R12
ldrb r0,[r8],#1
bic r8,#256 ; Assume queue is located at address of form xxxx0xxxxxxxx.
b MAIN_LOOP
POLL_BUS:
ldr r5,[r10,#PORT_OFS] ; Assume R10 always holds port base
and r0,r5,r7 ; Assume R7 always holds mask
cmp r0,r6 ; Assume R0 holds compare value
addeq r12,#(POLL_BUS2-POLL_BUS)
b r14
POLL_BUS2:
str r5,[r9],#4
bic r9,#256 ; Assume queue is located at address of form xxxx0xxxxxxxx.
add r12,#(POLL_BUS3-POLL_BUS2)
POLL_BUS3:
ldr r0,[r10,#PORT_OFS] ; Assume R10 always holds port base
cmp r5,r6 ; See if anything changed
addne r12,#(POLL_BUS-POLL_BUS3)
b r14
Note that code never goes very long without a bl R12
which calls one of the POLL_BUS functions, and none of those take very long before returning. Keeping everything in dedicated registers allows the code to run much faster than would be possible in C. The above code would be designed to capture four-byte records any time the bus state changes to a particular pattern; once it grabs something, it will wait until something on the port (whether masked or not) changes before grabbing the next item.
