I have bought a 200kg load cell and an AD620 in-amp. I only want to use 100kg as the maximum weight capacity. I want to power the load cell and the in-amp from the 5v pin of the arduino. The seller can't give me the specifications of the load cell so i'm actually having some difficulty computing for the gain.
I want an output swing of about 0 - 5V from the in-amp so i can utilize the 10-bit ADC resolution of the arduino with the default 5v reference.
Do I have to use a dual +-5V supply to have an output swing of 0-5V? What could I connect to the reference pin of the in-amp if i only have a single supply as I mentioned earlier.
I would really appreciate your help, this is for my thesis.
-----------------------------------UPDATE--------------------------------------
After I have read the datasheet and some books about amplifiers, I have tried to make a circuit so I can check if I could get the -Vs+1.1 to +Vs-1.2 output swing of the Ad620. Below is the circuit:
I have referenced the REF pin of the AD620 to half the supply by connecting it to the output of the LM741 op amp with two 10k resistors on the non-inverting pin. After testing some load and testing some gain resistor(as i have said earlier, the seller didn't give me the datasheet of the load cell so i dont know exactly what the exact sensitivity is), I have read an output swing of approximately half of my supply to 3.6V. That would be like 2.2V(because when i test the voltage supply from the arduino its like 4.4V) to 3.6V. Am I getting the right output from the AD620?
