I have a bunch of PICs that have been sitting in the basement for a year, and I really want to learn how to program and put them to use.
I have some 16C57's, 16C73, 16C71, 16C54, 16C74, 16C55, and 16C505. Some are write only, but a few from each category are erasable.
I want to do basic I/O with LED output and digital voltage sources.
What are the basic components I need, and where can I find instructions on programming them assuming I am a beginner programmer.
For example, if I acquire a USB programmer, do I also need a crystal, capacitors etc. for a basic setup?
closed as too broad by Keelan, Ricardo, Daniel Grillo, PeterJ, Matt Young Dec 12 '14 at 13:14
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ For the crystals,caps and other components you call check the datasheet of you device to see how to use it and program it. \$\endgroup\$ – GmodCake Dec 12 '14 at 4:27
    \$\begingroup\$ This question is too broad for the SE format. Could you try asking a more specific question (maybe only the last one)? Also, did you search for things like 'PIC tutorial', 'PIC circuit diagram', etc? There's a lot of resources out there. \$\endgroup\$ – Keelan Dec 12 '14 at 8:25
I would say that you lose your PICs in the basement. They are "C" devices and do not have Flash. This means that they may be erasable by UV (Quartz Window) or totally non-erasable OTP devices.
You should start with some new generation PIC microcontrollers which require less elaborate setup than the older series.
Here is a PIC tutorial to get you started.
To program new generation PIC you would minimally need:
  1. MPLABX environment setup on a machine (Windows or Linux) MPLABX
  2. A PICKIT3 to program and debug your PIC PICKIT3
  3. A Breadboard to experiment Breadboard
  4. A basic 5V or 3.3V power supply Power Supply
You may not need crystals and caps as most of the ne generation PICs come with an internal oscillator.
    \$\begingroup\$ "You may not need crystals and caps" - except maybe for decoupling. \$\endgroup\$ – Roger Rowland Dec 12 '14 at 10:26
  • \$\begingroup\$ For the newer generation PICS, I do not need Xtals. What about when I get to the older ones like the ones I have \$\endgroup\$ – skyler Dec 12 '14 at 16:31
