I'm communicating with my ZTE MG2639 module through UART. Few seconds after powering it and getting +CPIN and +STKPCI it just turns off (goes to stand by mode)
It only happens with SIM card, and after sending PIN.
What's wrong? I have tried on few different SIM cards and antennas.
  • \$\begingroup\$ I´m starting to use ZTE MG2639_V3, and I no have problems with serial communications, I have problems to connect GPRS. Your project with MG2639 module is OK ? I would like to share some ideas with you. \$\endgroup\$
    – user62722
    Commented Jan 5, 2015 at 16:30
  • \$\begingroup\$ I have found what was my problem. It looks like this module is draining huge current in quick burst and my power supply is to slow for that. I have added 1 cell LiPo and it's working like a charm! Thank you for your answer though. \$\endgroup\$
    – Ekci
    Commented Jan 5, 2015 at 20:18
I have found what was my problem. It looks like this module is draining huge current in quick burst and my power supply is to slow for that. Adding 1 cell LiPo did a trick.
