Has anyone hacked an IOS cable and knows what data is going in and out of which wire. Maybe a diagram of an iphone cut cable?
  • \$\begingroup\$ Yes, someone has hacked it and made diagrams of the pinouts. Do you have a more specific question? Which data do you want to access? \$\endgroup\$ – endolith May 17 '11 at 21:48
  • \$\begingroup\$ ^ that website does not work \$\endgroup\$ – luca590 May 18 '11 at 2:04
  • \$\begingroup\$ and where can i find the diagrams because i have not seen any and i have been looking \$\endgroup\$ – luca590 May 18 '11 at 2:05
  • \$\begingroup\$ ipl.derpapst.eu/wiki/Dock_Connector \$\endgroup\$ – endolith May 18 '11 at 3:18
Pinouts.ru has a great description of the connector.
The iPodLinux wiki has a great page describing the serial protocol.
Here is the connector diagram (with the blank side of the connector facing up):
Pins 12 and 13 are Tx and Rx, respectively. Rx and Tx are TTL level. Pin 1 is GND, and pin 21 is serial enable. To enable the serial port, tie a 6.8 kΩ resistor to GND.
    \$\begingroup\$ @GeorgeH, can you please bring over the information from your post and explain here. Links die, but Stack exchange never will. \$\endgroup\$ – Kortuk May 17 '11 at 23:28
  • \$\begingroup\$ Sorry - I tried, but the pinouts.ru page has a pretty in depth table that I couldn't figure out how to bring over. \$\endgroup\$ – George May 17 '11 at 23:52
  • \$\begingroup\$ @GeorgeH, Just sharing that a good source often dies but SE keeps it data available for download regularly. If the link dies your answer does not have any substance. \$\endgroup\$ – Kortuk May 18 '11 at 0:02
  • \$\begingroup\$ is there a diagram (picture) of which wires send which signal? thats what im asking \$\endgroup\$ – luca590 May 18 '11 at 2:03
  • \$\begingroup\$ I edited my answer to add an image of the connector \$\endgroup\$ – George May 27 '11 at 1:05
