One of the questions in my textbook (Introduction to Computing Systems) asks to design a 3-input AND gate. The given solution is as follows:
Given 3-AND gate solution
If I am reading this correctly, this is a 3-NAND–NOT combination. I don't understand why you need the NAND–NOT instead of just creating an AND by itself. My proposed schematic is the following:
My proposed 3-AND gate
This seems simpler, and uses fewer transistors, so I'm guessing that there's some reason that it won't work (otherwise it would be the example solution!). I don't see any possibilities for short-circuiting: if NAND(A,B,C), then NOT OUT, so there will be no path from power to ground (because it would have to go through OUT). On the other hand, I do think that everything is properly grounded: if NAND(A,B,C), then OUT should have a path to ground through whichever of (A,B,C) is logically false.
What am I missing?
  • \$\begingroup\$ I'm not quite sure how to use the schematic editor. If someone wants to replace my images, please feel free! \$\endgroup\$ – wchargin Dec 14 '14 at 17:55
  • \$\begingroup\$ You're missing how MOSFETs work and what the gate voltage (Vgs) has to be. \$\endgroup\$ – Majenko Dec 14 '14 at 17:59
  • \$\begingroup\$ Related: electronics.stackexchange.com/questions/143811/… \$\endgroup\$ – Ignacio Vazquez-Abrams Dec 14 '14 at 18:04
The problem here is that you're misunderstanding (or not having the basic understanding) of how MOSFETs work, in particular the \$V_{GS}\$.
On an N-channel MOSFET the gate voltage has to rise a certain amount above the source pin. On a P-channel it has to fall a certain amount below the source pin.
In your schematic the N-channel's source is connected to \$V_{CC}\$ and the P-channel's to GND. If the threshold is, say, 1.2V (a reasonable logic level threshold), then the input logic HIGH would have to be at least 1.2V above \$V_{CC}\$ and the logic LOW would have to be below -1.2V.
That, as you can see, just isn't practical.
  • \$\begingroup\$ You're certainly right that I don't understand how these work :) Is $V_{CC}$ just the battery/power voltage? (The bar at the top of my hand-drawn schematic?) And what is $V_{GS}$? \$\endgroup\$ – wchargin Dec 14 '14 at 18:13
  • \$\begingroup\$ Hmm...so is the key that the gate voltage is compared relative to the source voltage, as opposed to, say, \$0\,\mathrm{V}\$? In that case, would it ever make sense to connect an N-type transistor to power or a P-type transistor to ground? \$\endgroup\$ – wchargin Dec 14 '14 at 18:30
  • \$\begingroup\$ There are times when you would do that, but you generally require a special driving circuit. In normal logic it's never used like that. \$\endgroup\$ – Majenko Dec 14 '14 at 19:10
  • \$\begingroup\$ \$V_{GS}\$ is the difference in voltage between the gate and the source pins. \$V_{CC}\$ is the supply voltage (battery voltage). \$\endgroup\$ – Majenko Dec 14 '14 at 19:11
  • \$\begingroup\$ Thanks very much for your help! You've certainly given me some things to think about. \$\endgroup\$ – wchargin Dec 14 '14 at 22:14
