I was looking the ADP3338 LDO Regulator of Analog Devices and i'm wondering whats the output voltage of this LDO? http://www.analog.com/static/imported-files/data_sheets/ADP3338.pdf
Is the output voltage same of input?
What would be the point of that?
The answer to your question is: It depends which ADP3338 you get - they come in a range of output voltages from 1.5V right up to 5V. See the table on page 13 of the datasheet.
