In want to interface Incremental encoder sensor output to Microcontroller which is 10 meters away from the sensor.
Specifications:
Sensor Output : Square wave 0V to 5V , 100KHz frequency.
Controller: F28M35H52C, Interface Module: EQEP (Enhanced Qudrature Encoder Pulses)
As per my understanding, the available options are:
  1. Convert sensor output to differential ended signals using RS422/LVDS etc....
  2. Convert sensor output to differential ended signals using OP Amps etc....
Is my approach correct? Can i use RS422/RS485 for interfaces other than UART?
Kindly suggest the best method(s). Cost is not a big concern for me, time and reliability are in my interest.
  • \$\begingroup\$ Sounds like a 4-20 loop would do nicely. \$\endgroup\$ – Ignacio Vazquez-Abrams Dec 15 '14 at 5:46
An incremental encoder, so you have two signal lines plus maybe an index pulse, at a minimum.
You should be able to use RS422 or RS485 drivers (the latter can be constantly enabled) and receivers to send a differential signal over a few pairs. If you use shielded twisted pairs, properly terminated, it should be more than okay. If the EMI environment is hostile, consider isolation.
You could use inexpensive shielded Ethernet cable if that suits your other requirements.
  • \$\begingroup\$ @ Mr. SPEHRO PEFHANYL: Thanks for your reply. I have one more but similar query regarding Analog hall effect sensor interface. \$\endgroup\$ – Govinda R K Dec 16 '14 at 8:20
  • \$\begingroup\$ @ Mr. SPEHRO PEFHANYL: Thanks for your reply. I have one more similar query regarding Analog hall effect sensor interface. Specifications are: Sine wave whose magnitude varies from 1V to 4V . Maximum frequency 300Hz. Sensor max o/p current is:1.5mA Max. How to transfer this analog output to 10 meter long?? My idea is to use Op-Amp buffers, but not sure, whether Op-Amp can drive the cable capacitance or not? Request you to suggest reliable method. \$\endgroup\$ – Govinda R K Dec 16 '14 at 8:34
