I am trying to learn how to program the AVR XMEGA by using the XMEGA-A1 Xplained kit with a JTAGICE3 programmer. I am going through the Xmega Basics pdf (link).
In one of the instructions I am told to open I/O view for the LED port and look at the registers. I should see something like this:
Instead my I/O window looks like this. I get no PORTLED (which is defined in the board.h file). And my PORTE (where the LEDs are located) doesn't carry any information.
Does anyone know what I may be doing wrong?
  • \$\begingroup\$ Have you checked if you just don't have that column turned on? \$\endgroup\$ Dec 15 '14 at 10:16
  • \$\begingroup\$ How do I check this? \$\endgroup\$
    – EasyOhm
    Dec 16 '14 at 0:58
  • \$\begingroup\$ Right-click on the column headers, see if there is a way to change or modify them. \$\endgroup\$ Dec 16 '14 at 1:13
After a fresh install of Atmel Studio the view registers pane is off by default, it's the second button in the IO View window and I can see in your screen shot it's turned off. This was with a different ATxmega attached so the registers are different but it looks as follows once enabled:
