I have a room with 30 objects which may or not be present, and I want to be able to detect which objects are in the room.
My first idea was to attach a RFID tag to each one of these objects and have a sensor detecting them, but then I have frequency collision problems and since the room is quite large, I also cannot activate tags which are further away. Or I may be missing something...
I would also want to have objects not carrying an active radio transmitter, i.e., no batteries wandering around, just RFID tags or resonant metal pieces.
I could use cameras but image processing would require an Arduino on steroids.
This is for a hobby project since I need an excuse to use my Arduino again :P
How would you solve such challenge?
  • \$\begingroup\$ Maybe it would be enough to detect when the objects are entering/leaving the room? \$\endgroup\$
    – Eugene Sh.
    Dec 15, 2014 at 16:45
  • \$\begingroup\$ Room-sized RFID loop, using the lower-frequency kind of tag? \$\endgroup\$
    – pjc50
    Dec 15, 2014 at 17:12
  • \$\begingroup\$ The room may have several entry points, or it could even be an outside environment. Imagine I want to know how many people are in my terrain which has around 100m of radius. \$\endgroup\$
    – nemewsys
    Dec 15, 2014 at 18:52
This: -
And this: -
Are technically incompatible requirements. I suggest you lower your expectations but I hope someone basically proves me wrong.
