I have the following
Tiva C Board (TM4C123GXL) Code Composer Studio v6 using GCC
Compiling this sample code:
* main.c
#include <stdint.h>
#include <stdbool.h>
#include "inc/hw_types.h"
#include "inc/hw_memmap.h"
#include "driverlib/sysctl.h"
#include "driverlib/gpio.h"
int main(void)
uint8_t ui8LED = 2;
SysCtlClockSet(SYSCTL_SYSDIV_4|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3);
while(1)
// Turn on the LED
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3, ui8LED);
// Delay for a bit
SysCtlDelay(2000000);
// Cycle through Red, Green and Blue LEDs
if (ui8LED == 8) {ui8LED = 2;} else {ui8LED = ui8LED*2;}
This sample code is provided within the TivaWare works fine with the TI compiler (following all the steps in the workshop pdf). When I choose to compile with GCC using, If I do not include the driverlib.lib file it says undefined reference to the functions used above. If I include it it says two errors on the four functions
error: C:/ti/TivaWare_C_Series-2.1.0.12573/driverlib/ccs/Debug/driverlib.lib(cpu.obj) uses VFP register arguments, Test.out does not
failed to merge target specific data of file C:/ti/TivaWare_C_Series-2.1.0.12573/driverlib/ccs/Debug/driverlib.lib(cpu.obj)
I think everything should be fine when using TI compiler but I want to try GCC.
