On this schematic for a Z80 computer, there appears to be a thick blue wire connecting some components together. What is it? Googling yields no results: here is the schematic
  • \$\begingroup\$ Where is the schematic? \$\endgroup\$
    – Eugene Sh.
    Dec 16, 2014 at 17:29
    \$\begingroup\$ Without actually seeing through your eyes at the schematic that only you have, I can only guess that it may be a bus. \$\endgroup\$
    – Majenko
    Dec 16, 2014 at 17:30
  • \$\begingroup\$ Sorry, Forgot the link! \$\endgroup\$
    – user60684
    Dec 16, 2014 at 17:36
    \$\begingroup\$ Seeing your edited link, @Majenko is correct - it's a bus. It's a good alternative to running individual wires between components (leading to a very complex diagram) or just labelling them (leading to schematic wide hunting for the other corresponding label). \$\endgroup\$
    – LeoR
    Dec 16, 2014 at 17:38
  • \$\begingroup\$ So if it was built on a breadboard, I could just use individual wires? \$\endgroup\$
    – user60684
    Dec 16, 2014 at 17:44
Yes, they are buses. The address, and the data bus.
They are basically a way of drawing lots of nets without having to draw each individual one. The label by the nets that connect to it define what connections are inside the bus.
