In this project i want to control dc motor with numeric keypad. when I push a button first time, it works properly but when i push a button second or third times it does not react and it stays button that I pushed first.
Here is the code:
#include "io430.h"
#include "in430.h"
#define ileri BIT0
#define geri BIT1
void main(void)
  WDTCTL = WDTPW + WDTHOLD;
  DCOCTL=CALDCO_1MHZ;
  BCSCTL1=CALBC1_1MHZ;
  P1OUT = 0x00;
  P1DIR = 0x0F;
  P2OUT  = 0x00;
  P2DIR &= ~BIT0;
  P2IE   = BIT0;
  P2IFG  = 0x00;
  _BIS_SR(GIE);
  for(;;);
#pragma vector=PORT2_VECTOR
__interrupt void P2_ISR(void)
 if((P1IN && 0xF0) == BIT5+BIT6+BIT7)
 {P1OUT =BIT0;P2IFG  = 0x00;}
 if(((P1IN && 0xF0)== BIT6+BIT7) && (P1IN && BIT5) == 0)
 {P1OUT =ileri+BIT2;}
P2IFG  = 0x00;
} when I push a random button and interrupt enable for ex. if(P1IN == BIT5+BIT6+BIT7) =1 and so P1OUT =0X01;. It is okay there is no problem but, if I push another button, second interrupt does not work. Although if((P1IN == BIT6+BIT7) && P1IN!= BIT5) =1 , I cannot make P1OUT= ileri+BIT2.
Could you help me please?
  • \$\begingroup\$ Are you clearing the interrupt flag from the first button in your ISR? \$\endgroup\$ Commented Dec 16, 2014 at 20:13
  • \$\begingroup\$ @SomeHardwareGuy looks like this line does P2IFG = 0x00; \$\endgroup\$
    – Eugene Sh.
    Commented Dec 16, 2014 at 20:36
  • \$\begingroup\$ Is P2IE = BIT0; only enabling a single input bit to be an active interrupt. In other words is your mask set correctly? \$\endgroup\$ Commented Dec 16, 2014 at 20:43
  • \$\begingroup\$ He has a single interrupt on p2.0, which then polls the state of p1 pound 4-7. \$\endgroup\$
    – Passerby
    Commented Dec 16, 2014 at 20:48
  • \$\begingroup\$ Yeah I see that now, trying to do too much at once... \$\endgroup\$ Commented Dec 16, 2014 at 20:54
P1IN reads the state of all of P1, not just the pins set to input. Once any of p1.0-3 Are set to logic 1, P1IN will also include those bits. Example:
If P1.5-P1.7 are high, P1IN = 0b11100000
And you set P1.0 high, P1OUT = 0b00000001
Then read P1IN again, P1IN = 0b11100001
So basically you need to mask P1IN when you test it in your if statements.
if ( (P1IN & 0xF0) == BIT5+BIT6+BIT7) {P1OUT =BIT0;}
For example:
P1.1, P1.5, and P1.6 are high, P1IN = 0b01100001
Bitwise And P1IN and 0xF0 aka 0b11110000 to mask the bits you don't want
you get 0b01100001 & 0b11110000 = 0b01100000 aka 0x60
BIT5 = 0b00100000, BIT6 = 0b01000000, BIT7 = 0b10000000
Added together, that's 0b11100000 aka 0xE0
So you are testing if 0x60 equals 0xE0, which it does not.
Because of that, your second if statement also fails. If P1IN != BIT5, it will be true unless P1IN only equals 0b00100000.
Since the mm74c922 is a simple encoder, outputing 16 known states in binary, on 4 pins, you never need to mess with that type of not equal test, or double tests.
You can test for BIT5+BIT6+BIT7 or BIT6+BIT7, and they will never both be true at the same time, as these are absolute tests.
An easier way, is simply use the bitwise right shift operator >> for the test, and then compare to the actual output of the mm74c922. The >> takes a value and moves it right x number of bits. Any bits that are shifted out are lost, in this case masking them out. In this case, shifting right by 4 means you lose the lower nibble, and the upper nibble becomes the lower nibble.
Remember how BIT5+BIT6+BIT7 =  0b11100000 = 0xE0?
Shifted right by 4, it becomes 0b00001110 aka 0x0E aka 14!
BIT6+BIT7 = 0b11000000 shifted by 4 is 0b1100 aka 0xC aka 12!
if ( (P1IN >> 4) == 14) {P1OUT = BIT0;}
if ( (P1IN >> 4) == 12) {P1OUT = ileri+BIT2;}
Finally, since there are 16 (only 12 used) known states, a switch statement is better than a bunch of if statements.
switch (P1IN >> 4) {
     case 1:
      //do something when var equals 1
      break;
    case 2:
      //do something when var equals 2
      break;
    default:
      // if nothing else matches, do the default
      // default is optional
Here is a good tutorial on bitwise operators http://www.avrfreaks.net/forum/tut-c-bit-manipulation-aka-programming-101
  • \$\begingroup\$ I changed like this. When I debug step by step diagram is ok. it checks all if statements and go back for(;;) but, it skip if inside. what i am saying is that it check an if statement but although this if statement is true, it does not P1OUT=BIT1. @Passerby \$\endgroup\$ Commented Dec 16, 2014 at 22:10
  • \$\begingroup\$ if((P1IN && 0xF0) == BIT5+BIT6+BIT7) {P1OUT =BIT0;P2IFG = 0x00;} if(((P1IN && 0xF0)== BIT6+BIT7) && (P1IN && BIT5) == 0) {P1OUT =ileri+BIT2;} \$\endgroup\$ Commented Dec 16, 2014 at 22:10
  • \$\begingroup\$ @AliAKÇAKMAK fixed and updated. \$\endgroup\$
    – Passerby
    Commented Dec 17, 2014 at 1:54
  • \$\begingroup\$ Thank you very much it works. I really appreciate . This info is really usefull for me. \$\endgroup\$ Commented Dec 17, 2014 at 17:41
