I am using a Microchip MCP9808 I2C temperature sensor (https://learn.adafruit.com/adafruit-mcp9808-precision-i2c-temperature-sensor-guide/overview).
I'm having problems being able to calculate the temperature using the values I'm reading from the sensor.
The temperature is 13 bits wide. According to the datasheet, I need to send two read commands, the first read to return the upper byte and the second read will return the lower byte. 3 of the remaining bits are used to indicate temperature alarms, and 1 bit is used to indicate the sign of the reading (positive or negative).
I'm able to read the two bytes, by using the sample code from the datasheet as a starting point. However, the values I'm getting from it are incorrect. I'm also unable to get negative temperatures, so I think my code has something wrong with it.
I'm using a USB->I2C adaptor, and I've written a C# implementation of the datasheet sample code to calculate the temperature.
And then my code (which apart from some extra necessary castings due to the way C# handles data types) I think is identical.
    public static double CalculateAmbientTemperature(byte upperByte, byte lowerByte)
        const byte ALERT_MASK_VALUE = 0x1F;
        const byte CLEAR_SIGN_MASK = 0x0F;
        double temperature = 0.00;
        upperByte = (byte)(upperByte & ALERT_MASK_VALUE);
        // Ambient temperature less than 0 degrees
        if((upperByte & (byte)(upperByte & 0x10)) == 0x10)
            upperByte = (byte)(upperByte & CLEAR_SIGN_MASK);
            temperature = 256.0 - ((double)upperByte * 16.0 + (double)lowerByte / 16.0);
        else
            temperature = ((double)upperByte * 16.0 + (double)lowerByte / 16.0);
        return temperature;
So to test the code, I've been sending the bytes: START_BIT 0x3E (the address) 0x05 (the address of the temperature register) This tells the sensor to point the register pointer at the temperature register, so that when I send the two read commands, it reads from that register.
And when I read the data back, I'm getting 0xC1 0x24. When I pass these values to the function, I'm getting 17.0625 degrees C. Bearing in mind, I'm holding an ice cube on the sensor. (Currently don't have a more precise way). So basically, my calculation is faulty but I don't know where to begin with fixing it.
Any help would be appreciated.
(EDIT: To check I'm able to read the chip correctly, I read the Manufacturer ID register and get back the expected 0x54)
  • \$\begingroup\$ Your CLEAR_SIGN_MASK looks incorrect. It should be 0x1F \$\endgroup\$
    – Eugene Sh.
    Commented Dec 16, 2014 at 22:37
  • \$\begingroup\$ Oh, come on. There's always a better way. Crush some ice, make an ice/water slurry in a bowl, put your sensor in a plastic bag, immerse it in the ice/water mixture, and give it time to come to equilibrium. You'll be very near zero. \$\endgroup\$ Commented Dec 16, 2014 at 22:38
  • \$\begingroup\$ @EugeneSh. How so? The datasheet says 0x0F? \$\endgroup\$
    – user9993
    Commented Dec 16, 2014 at 22:40
  • \$\begingroup\$ @user9993 Sorry, missed one bit. Disregard :) \$\endgroup\$
    – Eugene Sh.
    Commented Dec 16, 2014 at 22:42
    \$\begingroup\$ I manually calculate those values as 18.25 degrees. But then, I got the order of precedence right in my calculation. Tip: don't work in double till right at the end. Keep it as integers. \$\endgroup\$
    – Majenko
    Commented Dec 16, 2014 at 22:43
I've run into this problem myself recently. The error originates from the manufacturer's datasheet. When the 'negative' flag is set the proper computation is:
temp -= 256;  // correct!
instead of
temp = 256 - temp;  // incorrect! But this is the example in the datasheet!
Here are a couple examples of control code for the MCP9808 on Github:
lexruee/mcp9808
adafruit/Adafruit_MCP9808_Library
  • \$\begingroup\$ Thanks for the edits. Also: I've submitted a documentation bug report to Microchip. We'll see how they respond. \$\endgroup\$
    – Freshness
    Commented Jul 8, 2016 at 15:06
  • \$\begingroup\$ Did they ever respond? @Freshness \$\endgroup\$
    – user9993
    Commented Jun 21, 2017 at 10:02
  • \$\begingroup\$ No, they did not. I git a survey request about a year later and scored them pretty low, but no acknowledgement and no change in documentation. \$\endgroup\$
    – Freshness
    Commented Jul 7, 2017 at 8:35
  • \$\begingroup\$ How annoying! @Freshness \$\endgroup\$
    – user9993
    Commented Jul 7, 2017 at 9:04
  • \$\begingroup\$ I have used the calculation from datasheet, and it gives correct values. Your modified equation gives false results. \$\endgroup\$ Commented Sep 24, 2017 at 18:52
