I am new to the avr (8bit uc) and recently I ran into a problem using serial communication (uart) with PC. Microcontroller fails to responsd in putty terminal where it should echo back whatever I have sent.
Thank you for your response everyone .
I am sorry for the corrupt code I had no idea what I was doing since I am newbie to this code indention in stack exchange.
The new code is attached below please kindly suggest
#define F_CPU 16000000UL
#include <avr/io.h>
#include <avr/interrupt.h>
volatile char data;
void USARTInit(uint16_t ubrr_value) {
UBRRL = ubrr_value;
UBRRH = (ubrr_value >> 8);
UCSRC = (1 << URSEL) | (1 << UCSZ0) | (1 << UCSZ1);
UCSRB = (1 << RXEN) | (1 << TXEN);
void USARTWriteChar(char data) {
while (!(UCSRA & (1 << UDRE)))
//Now write the data to USART buffer
UDR = data;
void main() {
sei();
UCSRB |= (1 << RXCIE);
USARTInit(51);
while (1) {
if (data == 'a') {
USARTWriteChar(data);
ISR(USARTRXC_vect) {
data = UDR;
so here foo just represents my data='a', unfortunately avr is not responding to my inputs . when I type "a" .
if(data==1) }
at the end there... \$\endgroup\$
