I'm working on a hobby project where I'm trying to drive a solenoid valve with an arduino (for some automated plant watering).
The solenoid valve takes 12v, so I've rigged up some smaller batteries in series to supply that 12v. That works - when I plug the solenoid valve directly into the battery, it opens. According to its spec sheet, the valve can draw 500mA. (Although that's a lot, I only need to do it for a few seconds maybe every few hours). YOu can see the solenoid's specs here: http://www.ebay.com/itm/1-2-Gravity-Feed-Electric-Solenoid-Valve-DDT-CD-12VDC-/290763981675
Next, I made a little circuit that toggles an LED with a transistor - a digital pin from the arduino (5v) is the base input, and the LED is fed by the battery (so battery positive->led->collector->emitter->battery negative). That works too, the light blinks on and off (driven by code). This works whether the power source is the battery or the arduino (although I found I had to give the two circuits a common ground for that to work).
However, when I hook up everything together (all powered by batteries), the LED still toggles, but the solenoid doesn't. Is this a problem with high-side vs. low-side transistor wiring? (I'm kind of hazy on the distinction, but if it works for the LED, then that part of the circuit is correct, right?).
The NPN transistor is an MPS 2222. I think from its fact sheet, it ought to be able to handle this load, right? Am I reading it wrong, and do I need to upgrade to one with a higher current capacity, or better voltage limits: http://www.farnell.com/datasheets/115091.pdf
Also, is it enough to use an LED to protect the circuit from back-emf when the solenoid is turned off?
Thanks! In the photos below, the black cable coming in from the bottom left is the digital signal from the arduino. The yellow wire (and the stuff around it) are an unrelated sensor thing. The two metal tabs at the top are the solenoid valve.
details of the transistor Here's the circuit all together
  • \$\begingroup\$ It would be of great help if you could insert a circuit diagram. The site provides a handy tool in the question editing menu, if you have no facility to make a nice one with your own tools \$\endgroup\$ Dec 20, 2014 at 14:18
No, this transistor cannot be expected to do this job for long, if it can do it at all.
From the datasheet, look at the "On characteristics" on page 2. First, its free air power rating is 0.625W, which means Vce had better be 1.25V or less at 500 ma.
Then, gain (hFE) is shown at different Vce voltages and currents. But significantly, not shown at Vce=1V and Ic=500mA, suggesting that the transistor is not rated to work under those conditions.
Finally, the CE saturation voltage is shown as 1.6V at 500mA, which exceeds the power rating shown above. You will be able to get away with that for a few seconds on a very low duty cycle. The MPS2222A would be a better choice, its Vce(sat) is shown as 1V here.
But...the above condition is achieved with Ib=50mA. This almost certainly exceeds the current available from your Arduino output pin.
If you are content to briefly overrate the device's power ratings, you could overcome the base current limitation using a second transistor as an emitter follower, to drive the base current you need.
(schematic editor isn't loading this morning, sorry)
You have the solenoid wired in series with the LED, so they are both drawing the same current - which is enough to light the LED but not to operate the solenoid. You need to connect the solenoid in parallel with the LED and 3.9k resistor, ie. directly from battery positive to the transistor's collector.
Also you need to increase the base current to keep the transistor in saturation at 500mA. The MPS2222 has a minimum hFE of 30 at 500mA, so it may need up to 17mA on the Base. The Arduino should have no problem supplying this current. Assuming the Arduino puts out 4.5V and the base drops 0.7V at 17mA, the resistor between Arduino output and MPS2222 base needs to be 220 Ohms or less (3.8V/17mA). You don't need a resistor between base and emitter.
The MPS2222 can barely handle 500mA, but it should be OK so long as it is driven into saturation and you only operate the solenoid for a few seconds.
You cannot use the LED to protect the circuit from back-emf when the solenoid is turned off. The voltage across the solenoid will go negative until it reaches the LED's reverse breakdown voltage, possibly blowing it up. You should use a rectifier diode such as 1N4001 or 1N5817.
