what happens when you increase the power of bluetooth? Is it possible to increase the range of a bluetooth signal?
Each particular Bluetooth module will have a maximum amount of transmit power, like +8 dBm, and you can run up to that maximum (using more supplied power to the module) or run at a lower level. The higher the transmit power, the longer the range.
But you also have to be able to receive the signal from the other end. Each module will also have a corresponding receive sensitivity, the lower the better (i.e. -98 dBm is betetr than -86 dBm) This number is fixed for each module and not something you adjust. A high transmit power with a lousy receiver sensitivity doesn't help.
Different chips will be designed to run at different levels of maximum power, and type of transmitter.
Using some of the Bluegiga modules, whith which I am the most familiar, some figures are:
Model Max Transmit Max Receive Sen Range (m)
WT12 +3 dBm -86 dBm 20-30
WT11i +17 dBm -86 dBm 100-300
BLE112 +3 dBm -93 dBm 30-150
BLE121LR +8 dBm -98 dBm 450
The WT12 is a class 2 "classic" Bluetooth module, and the WT11i is a class 1 "classic" Bluetooth module. The last two are both BLE (Bluetooth Low Energy), aka Bluetooth 4.0. Note that the BLE121LR (LR for long range) gets a much greater range using +8 dBm of transmit power than the WT11i does with 17 dBm.
The range figures in meters are all for line of sight, outdoors. Figures for indoors, or outdoors with obstructions, will be lower.
In the past, it was pretty much the case Bluetooth range was limited to 100 meters. You can see with different modules, you can now go anywhere from 20 to 450m.
Note: these figures were all obtained with the built-in "chip" antennas on the Bluetooth modules.
I have no association with Bluegiga other than being a customer.
\$\begingroup\$ Great answer, just one tidbit about the BLE121LR. In that specific case, the range is not only dependent on the power, but also designing a board with a specific ground plane around the module. Otherwise, spot on. \$\endgroup\$– SJoshiApr 19, 2015 at 3:00
\$\begingroup\$ @SJoshi Thx, I was wondering what some of the secrets were that allowed them to reach out that far. \$\endgroup\$– tcrosleyApr 19, 2015 at 4:12
\$\begingroup\$ No prob... The power amplifier they stick in their system helps too :) \$\endgroup\$– SJoshiApr 19, 2015 at 4:55
If you design your own bluetooth boards yes you can increase the signal strength by increasing the current or by changing the antennae type but when you get off the shelf bluetooth modules everything is predefined you can't help it .
2\$\begingroup\$ -1: "Increasing the current" does not make the chip capable of higher power output. Internally the chips have regulators anyway. There are modules which have an antenna output allowing you to use your own directional antenna. A directional antenna only affects the range if the the receiver is in the right direction and the reception sensitivity isn't the bottle neck. \$\endgroup\$ Apr 3, 2015 at 13:55
