I need to design an 8 bit up counter in VHDL using T flip flop and generate statement. I know how the counter works, but I am not able to design it in VHDL.
The main problem is "using generate statement" . As I can see, in an up counter (ripple or synchronous ; either is OK ; I decided to use ripple ) , the previous output is fed as a clock. So I can map Q(i -1) for clock in the i'th generated flip flop. But what about the first flip flop ? It has a clock explicitly applied.
So if I use generate statement, I cannot simply map the clock to previous output ; the first flip flop will always create problem. Another thought which came was to initialise first counter explicitly and then use generate statement for remaining 7 flip flops. But here as well, I think, the first (or rather, second) flip flop using generate statement will pose a similar problem ( ie mapping clock).
Am I incorrect or missing something important here ?
Here is the code ( planned code, not actual code) :
component tff is
Port ( t   : IN BIT ;
       clk : IN BIT ;
       q   : OUT BIT );
end component
--Other irrelevant stuff
For i IN 0 TO 7 GENERATE
tffx : tff PORT MAP ( tIn , q(i-1) , q(i) ) ;
end GENERATE ;
--More irrelevant stuff
Thank you.
  • \$\begingroup\$ Can you post your code for first thought? I think we can find a solution to fix your first flip-flop issue ;) It would be nice to have some code to work on. \$\endgroup\$
    – Paebbels
    Dec 21, 2014 at 8:51
  • \$\begingroup\$ The clock input for the first T-FF can be assigned outside the generate statement to the external clock input. \$\endgroup\$
    – TEMLIB
    Dec 21, 2014 at 11:16
  • \$\begingroup\$ @TEMLIB . Can you elaborate that a bit ? \$\endgroup\$ Dec 21, 2014 at 12:31
  • \$\begingroup\$ @Paebbels . As you can see from the code, mapping clock for 'zeroth' generated component is a problem . \$\endgroup\$ Dec 21, 2014 at 12:53
    \$\begingroup\$ You can move the indices by 1, so the index will not be negative :) \$\endgroup\$
    – Paebbels
    Dec 21, 2014 at 13:00
Here is a simple generate statement, which generates 8 TFFs and connects the clock input of the tff to the q output from previous FF. Because you are using indices calculations (i+1 or i-1), you need to wider range for the tff_clocks range or you must shorten the generate loop.
I'm using a loop from 0 to 7 so I extended tff_clocks by 1. Index 0 is connected to the original system clock.
architecture ....
  signal tff_clocks : std_logic_vector(8 downto 0);
begin
  tff_clocks(0)  <= clk;   -- first tff is clock with main clock
  genTFF : for i in 0 to 7 generate
    tff_inst : tff
      port map (
        clk   => tff_clocks(i),
        t     => '1',
        q     => tff_clocks(i + 1)
  end generate;
  async_counter_result <= tff_clocks(8 downto 1);
end;
