We're debating the use of the MPU-9150 IMU in an application. This IMU has a user settable full scale range for the accelerometer (e.g. 2g, 4g, etc) and gyroscope (200dps, 400dps, etc).
Suppose I set the values at 2g and 200dps - what happens at the boundaries of these ranges? Are the values ceiling/floored (i.e. an acceleration of 3g-4g results in 2g sent to back from the sensor), or do the values roll over?
  • \$\begingroup\$ A good question for the manufacturer, but I would certainly expect it to rail at the maximum number. Time for recovery from overload would be another question. \$\endgroup\$ – Spehro Pefhany Dec 21 '14 at 21:26
The MPU 6050 pegs at either end of the range (you can see the red series flat lining):
I assume the 9050 does the same, though haven't tested it. We use the 6050 in production.
  • \$\begingroup\$ It should considering the 9150 has a 6050 in it. Will go with this answer. Thanks! \$\endgroup\$ – darudude Dec 23 '14 at 4:01
Most likely the range selection changes an amplifier gain so that the ADC input range corresponds to the selected g range. If the sensor output is outside of this range, then it will simply be clipped to one end of the ADC range (min or max ADC code).
