6
In the past I have built several switched-mode supplies using off-the-shelf transformers just using the datasheet properties without having to worry too much about their construction, however I am working on a flyback design at the moment for which no readily available product will do, so I decided to wind my own.
I have some ungapped ferrite cores which I need to shave down to create the gap I require, I am quite comfortable calculating how big this has to be, however one little detail caught my eye - I am wondering whether the introduction of varnish will affect the behaviour of the air gap (assuming that varnish can get into the gap if I dip the whole thing in it). I have not seen any mentions of this anywhere, I am wondering whether it's because it does not matter or because I'm looking in the wrong places. I am not an expert in magnetics so I don't want to rely on my vague intuition, however I have the following equation for the flux \$\phi\$ in a gapped transformer core:
$$\phi=\frac{ANi}{l_c/\mu_c+l_g/\mu_g}$$
Here \$N\$ is the number of turns, \$i\$ is the current through each turn, \$l_c\$ and \$l_g\$ are the effective path lengths in the core material and gap respectively, \$\mu_c\$ and \$\mu_g\$ are the permeabilities of the core material and gap respectively (the latter being practically \$\mu_0\$ if it's air), and the effective cross sectional area \$A\$ is assumed constant for both the core material and the gap (neglecting fringing). Of course all of this assumes the core is not saturated.
I figured I can rearrange the equation to see the effect of the gap more directly:
$$\phi=\frac{ANi\mu_c/l_c}{1+l_g/l_c\cdot\mu_c/\mu_g}$$
The ratio of the gap length to the effective length in the core \$l_g/l_c\$ is somewhere in the order of \$10^{-2}\$, and (assuming the gap permeability is in the order of \$\mu_0\$) the ratio \$\mu_c/\mu_g\$ will be somewhere in the order of \$10^{3}\$. Hence, the combined term \$l_g/l_c\cdot\mu_c/\mu_g>>1\$, so - just for the purposes of a crude simplification - the equation can be approximated as:
$$\phi\approx\frac{ANi\mu_g}{l_g}$$
This shows that for the given approximate range of gap sizes and magentic properties, the magnetic circuit behaves (almost) as if it consisted only of the air gap, but more relevant to the current topic, that the flux is close to being proportional to \$\mu_g\$. I suppose this makes sense as in this scenario the core acts basically as a magnetic short circuit - but, the question this raises is that if the gap is calculated assuming that it contains air with a permeability very close to \$\mu_0\$, what happens when I dip the transformer in insulating varnish? If the varnish gets into the gap, does it change the effective permeability in the gap? Magnetic permeability does not seem to be a commonly listed property in insulating varnish spec sheets, and I don't know enough about magnetics to comfortably assume that the permeability of varnish would be close to \$\mu_0\$. Is this a valid assumption, or is there anything missing here? If it is valid, is there perhaps anything funny that happens at higher frequencies that would affect these effective material properties?
Many thanks!
    \$\begingroup\$ +1 Nice question. What Spehro says (he's usually right :-) ). I liked the often not realised " ... for the given approximate range of gap sizes and magnetic properties, the magnetic circuit behaves (almost) as if it consisted only of the air gap ...". ie yes, for energy storage purposes the rest of the core is "almost not there" and the air gap is what it's all about. \$\endgroup\$
    – Russell McMahon
    Commented Dec 27, 2014 at 7:18
  • \$\begingroup\$ So basically the question is - what's the permeability of varnish? \$\endgroup\$
    Commented Dec 27, 2014 at 9:52
  • \$\begingroup\$ @RussellMcMahon - thanks, good to know my workings are consistent with reality! \$\endgroup\$
    – ew218
    Commented Dec 27, 2014 at 11:02
  • \$\begingroup\$ @Andyaka- I suppose that was a major part of it, but generally whether the introduction of varnish does anything to the air gap that I should be aware of (since the air gap dominates the behaviour of the magnetic circuit, I wanted to ensure that whatever is in there really acts as if it's air!) \$\endgroup\$
    – ew218
    Commented Dec 27, 2014 at 11:03
Rest assured you may safely assume that the magnetic permeability of varnish is close enough to that of air or vacuum (\$\mu_r \approx 1\$), and yes, the gap size will typically dominate many of the characteristics.
See for example this page, especially the non magnetic materials at the end of the table. Unless your varnish is loaded with metal or ferrite powder you should be fine.
  • \$\begingroup\$ Thanks for this, that's good to know. I did actually see the table in this Wikipedia article before posting my question, however when I did this didn't convince me of anything other than the fact that the permeability of many materials is close to \$\mu_0\$, as it was just a list of very common materials I saw no way of applying this to a very specific compound (in my case, the varnish I have is methyl ethyl ketoxime). Can I ask, just for my own peace of mind, what is it that makes it safe to assume that the varnish falls into this category? \$\endgroup\$
    – ew218
    Commented Dec 27, 2014 at 7:31
  • \$\begingroup\$ All the stuff that has a high permeability is attracted to a permanent magnet. Everything else is about 1 relative permeability except superconductors, which are repelled by a magnet. \$\endgroup\$ Commented Dec 27, 2014 at 7:45
  • \$\begingroup\$ Brilliant, thanks. Sorry to make you spell it out for me, this is one corner of physics I sadly haven't had the time to study properly yet. All makes sense though! \$\endgroup\$
    – ew218
    Commented Dec 27, 2014 at 10:57
    \$\begingroup\$ The permeability alone does not guarantee the material will be "invisible" to a changing magnetic field as in a transformer - the material should also be non conductive to prevent significant eddy currents as could happen with metals. Fortunately, the varnish satisfies both criteria. \$\endgroup\$ Commented Dec 27, 2014 at 14:08
  • \$\begingroup\$ Ah, this is the kind of thing I attempted to ask about at the end of my question by mentioning changes in behaviour with frequency (though admittedly I suggested I was looking for changes in properties which of course isn't always the same thing). I imagined something like this could take place, but wasn't sure what and didn't want to guess... my wave theory background is in acoustics so I try to resist the tendency to apply extrapolated guesswork from this field to EM where I am still very much an amateur, and instead replace it with actual knowledge bit by bit.. so thanks for clarifying! \$\endgroup\$
    – ew218
    Commented Dec 27, 2014 at 17:58
Change of phase of materials often results in change of mass or in this case thickness. Water to ice for instance. If the varnish filling the gap expands on curing you have a new gap size and new inductive properties to consider.
