I bought Nucleo F411RE and I'm using Keil uVision 5 as IDE for programming it. To download program to Nucleo, you simply copy it in the virtual nucleo drive:
uploading binary file to nucleo
Of course, I'd like to have this task automated. To do so, I tried to use the Keil project configuration:
keil run after compilation
But that doesn't work:
*** Error: CreateProcess failed, Command: 'copy build\Nucleo_blink_led_NUCLEO_F411RE.bin H:\'
So what should I do? Keil is recommended by Nucleo manufacturer, yet this simple issue seems to have no solution on the internet...
| improve this question | | | | |
I don't know why this didn't work, but xcopy command works well:
copy file nucleo keil
| improve this answer | | | | |
    \$\begingroup\$ Probably works because there is an xcopy.exe program, whereas copy is handled internally by cmd.exe \$\endgroup\$ – PeterJ Dec 28 '14 at 10:16
