12
I've been using various microcontrollers and microprocessors for many, many years now but I seem to be stymied by the Kinetis KE series (specifically the S9KEAZN64AMLC).
Jan 17, 2015 TL;DR:
Freescale confirms that v2.0.0 of their Kinetis Design Studio software does not work with this device (including their own TRK-KEA64 eval board). They recommend using CodeWarrior MCU V10.6 for the time being.
Segger has released v4.96a (the "a" is important, I was using v4.96) which corrects the issue and allows you to use a Segger J-Link Lite CortexM debugger board with KDS and have full program/debug capability.
Before Segger released v4.96a I managed to be able to flash the chip by reprogramming the OpenSDA debugger on Freescale's inexpensive ($15) FRDM-KL25Z eval board by reflashing the OpenSDA firmware it comes with with USBDM (using v4.10.6.240). I then used USBDM's standalone "ARM Programmer" software. I did not spend much time trying to get debugging working, as I am proficient enough at "oldschool" debugging to not need it. Please make sure that you flash a "benign" program into the on-board target KL25 or it may interfere with programming since the on-board target KL25's reset line is still connected to the OpenSDA debugger even with J11 cut (see Keith Wakeham's blog post, linked below).
A big thank you to Erich Styger for very very graciously helping me determine the issue and confirm my findings over email.
Now back to our regularly scheduled question:
I've built a stupid-simple 3.3V breakout board. It's got some LEDs on PTA, a UART connection on PTC and the SWD lines are on their dedicated lines. There's literally nothing fancy or funny about this board.
I'm using a J-Link Lite for Cortex-M (J-Link LITE CortexM-9, see https://www.segger.com/jlink-lite-cortexm.html) and under both OSX and Windows I get the same result: the J-Link Commander utility can identify the chip, I can read and write to SRAM and play around with the peripherals with manual reads and writes to the correct memory-mapped I/O address. When I try to flash the device, though, it fails.
$ JLinkExe
SEGGER J-Link Commander V4.94c ('?' for help)
Compiled Oct 31 2014 20:08:55
DLL version V4.94c, compiled Oct 31 2014 20:08:48
Firmware: J-Link Lite-Cortex-M V8 compiled Jul 17 2014 11:40:12
Hardware: V8.00
S/N: 518107921
Feature(s): GDB
VTarget = 3.332V
Info: Could not measure total IR len. TDO is constant high.
No devices found on JTAG chain. Trying to find device on SWD.
Info: Found SWD-DP with ID 0x0BC11477
Info: Found Cortex-M0 r0p0, Little endian.
Info: FPUnit: 2 code (BP) slots and 0 literal slots
Cortex-M0 identified.
Target interface speed: 100 kHz
J-Link>device skeazn64xxx2
Info: Device "SKEAZN64XXX2" selected (64 KB flash, 4 KB RAM).
Reconnecting to target...
J-Link>r
Reset delay: 0 ms
Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
J-Link>erase
Erasing device (SKEAZN64xxx2)...
(...several second pause while it communicates with the MCU...)
****** Error: PC of target system has unexpected value after erasing sector. (PC = 0xFFFFFFFE)!
---------------------------------------------------------------------- Registers -------------------------------------------------------------------------------------
    PC   = FFFFFFFE
Current: R0   = 00F3E3BE, R1   = 00000001, R2   = 4004801C, R3   = 00000001
    R4   = 00000000, R5   = 00000000, R6   = 000000F4, R7   = 1FFFFD61
Info: J-Link: Flash download: Total time needed: 2.174s (Prepare: 0.894s, Compare: 0.000s, Erase: 0.736s, Program: 0.000s, Verify: 0.000s, Restore: 0.542s)
ERROR: Erase returned with error code -5.
The J-Link Lite is perfectly fine (I can read and write to the nRF58122 SoC, another Cortex-M0 processor, with it) and the device seems to otherwise work. I know the Kinetis is unlocked as they're factory fresh stock from DigiKey, but even then the "kinetis unlock" command in JLinkExe times out without any error or useful information.
At this point in time I'm sure I'm doing something stupid, but I'm at a loss for what it could be.
Has anyone worked with these devices before? How are you programming them?
edit to add walkthrough:
Some more information:
I read that the NMI# pin is enabled out of reset (and verified this by reading SIM_SOPT) but also that it has an internal pull-up when enabled. On this particular part PTB4 is on pin 10 which is a no-connect in my design. Disabling the NMI pin makes no difference. RST# is similar; It's connected to a pushbutton that grounds the pin and also goes to the J-Link Lite but there is no external pullup. This shouldn't matter because like NMI#, the RST# pin has an internal pullup that is enabled when PTA5 is configured to be a reset.
Looking at clocking now... Out of reset, ICS is the clock source to the FLL and BDIV in ICS_C2 is set to 001 (the reset default). If I understand correctly, this means that the 32kHz internal oscillator is multiplied by 1024 by the FLL and then divided by 2, making ICSOUTCLK 32kHz * 1024 / 2 or 16.8MHz. I can verify through the J-Link CLI that the FLL is locked by reading ICS_S:
J-Link>mem8 40064004 1
40064004 = 50
(LOCK and IREFST are set, this is correct.)
I then move on to verify that the SIM has the clock enabled for the flash controller by reading SIM_SCGC. I can also quickly check to make sure that BUSDIV in SIM_BUSDIV is set to zero which means that the BUSCLK is the same frequency as ICSOUTCLK (i.e. it's not being divided down):
J-Link>mem32 4004800c 1
4004800C = 00003000
J-Link>mem32 40048018 1
40048018 = 00000000
So far, everything looks fine. BUSCLK is 16.8MHz and the flash controller clock isn't gated.
Now let's move on to the flash controller. Out of reset FCLKDIV is zero, and we need a 1MHz clock. Table 18-2 in KEA64RM shows that FDIV should be set to 0x10.
Out of reset:
J-Link>mem8 40020000 1
40020000 = 00
Setting up the divider and verifying things are good:
J-Link>w1 40020000 10
Writing 10 -> 40020000
40020000 = 90
FDIVLD is set and the correct value in FDIV is shown.
Before going too far ahead, let's make sure that the flash isn't protected:
J-Link>mem8 40020001 1
40020001 = FE
KEYEN = 11 (disabled) and SEC=10 (unsecured). Ok. Let's try to verify the device is blank:
J-Link>mem8 40020006 1
40020006 = 80
J-Link>w1 40020002 0
Writing 00 -> 40020002
J-Link>w1 4002000a 1
Writing 01 -> 4002000A
J-Link>w1 40020006 80
Writing 80 -> 40020006
40020006 = 83
Here we see that the MGSTAT bits in FSTAT indicate that blank check has failed and also that non-correctable errors were found. Odd. Let's try erasing it ourselves:
J-Link>w1 4002000a 8
Writing 08 -> 4002000A
40020006 = 80
The erase all command succeeded. Now let's try a blank check:
40020006 = 80
Now the blank check is fine?
At this point I'm about ready to give up, eat the loss on these prototypes and go with a processor from ST where I've never had these kinds of issues before. The Kinetis documentation is thorough enough but it is very dense and I'm finding it very difficult to get started. I can wiggle I/O through memory reads and access other peripherals but I can't for the life of me figure out what's wrong with the flash controller. I've been working with micros for over 20 years and this kind of difficulty is something I have never encountered before.
20150102 edit:
So still no go here. I have actually bought a FRDM-KL25Z eval board ($15 from DigiKey) and modified it by putting the generic CMSIS-DAP software on the OpenSDA debugger and cutting J11 as per Keith Wakeham's blog. I've got the on-board target (the KL25Z) running a simple program so it doesn't interfere with the reset line and I can see my SKEAZN64 with OpenOCD and play with it, but unfortunately it can't program it either. The Kinetis Design Studio (KDS) software won't flash my Kinetis because it says it's protected and I need to do a mass erase, but OpenOCD (as part of KDS) doesn't seem to know how to do this. The git master version of OpenOCD I built on my Mac understands Kinetis, but not the specific KEA series, so I'm back to square one.
Going back to the J-Link...
@AdamHaun had a really good clue, and if I set the J-Link reset type (rsettype command) to type '6' (Kinetis) J-Link is supposed to disable the watchdog after resetting the core. Looking at the WDOG_CS1 register (0x40052000) it does appear that that is the case, but still no dice. An erase operation seems to go off the rails with PC at 0xfffffffe and error code -5, and an "unlock kinetis" command only works if I disable the reset pin using SIM_SOPT (by writing the 32-bit value 0x00000008 to 0x40048004). Unfortunately if I do that the CPU cannot ever be halted again, presumably because the SWD interface can't use the reset line to force the SWD DAP into a known state.
20150103 edit:
I HAVE BLINKING LED
REPEAT
I HAVE BLINKING LED
TL;DR version: put the USBDM image on the FRDM-KL25Z board (a story all on its own), use the ARM Programmer standalone app to send the test .elf over to the board. Power cycle and voilà.
Long version will come later. I now have less than 48h to write and debug software for this KEAZN64 board, finish modifying/testing other software that goes with it, and work on some documentation for another client. I promise I will update this question with a detailed answer. I just wanted to share my success. Thank you EVERYONE for your assistance. I might have to speak with the mods because I would really like to give the bounty to a couple of you in particular.
  • \$\begingroup\$ Stupid question, but are you sure you're using the correct j-link lite? They're limited to one platform. Haven't used the wrong one myself, but this is how I'd expect it to fail. \$\endgroup\$ Dec 31, 2014 at 11:47
  • \$\begingroup\$ Given that the j-link and kinetis tags here have virtually no contents (just one other question), you should probably try finding some manufacturer's support forum or e-mail, phone support etc. forum.segger.com maybe? \$\endgroup\$
    – Fizz
    Dec 31, 2014 at 12:17
  • \$\begingroup\$ community.freescale.com/community/kinetis appears another venue where you might find people knowledgeable about this. community.freescale.com/thread/337779 appears to be a very similar if not exactly your question... \$\endgroup\$
    – Fizz
    Dec 31, 2014 at 12:25
    \$\begingroup\$ @RespawnedFluff I actually have an almost-identical question on the Kinetis forums: community.freescale.com/message/466015. e.se has FAR more reach and I prefer this community/site so I figured it wouldn't hurt to ask here too. \$\endgroup\$
    – akohlsmith
    Dec 31, 2014 at 14:41
    \$\begingroup\$ @RespawnedFluff Updated the question to include the specific J-Link version. It's not an OEM-specific one and states directly "Any Cortex-M0/M0+/M1/M3/M4/M7 core supported". \$\endgroup\$
    – akohlsmith
    Dec 31, 2014 at 17:12
5 Answers 5
I cannot actually find any logical errors in your procedure, but here are some suggestions:
  • there's also a FTMRH_FERSTAT register (at 4002_0007h). It's supposed to tell you what went wrong... but only in the case of parity (or double parity errors). I'm not convinced this will record anything in case or erase errors, but probably worth checking out.
  • the KEA documentation also mentions that an interrupt may be triggered by flash errors (section "18.3.5 Flash and EEPROM interrupts"). I don't know if that's what happens when the SEGGER erases it, but it is a plausible explanation as to why the PC changes too since you did see errors flagged in the FSTAT register. Unfortunately the KEA documentation section for the interrupt controller ("3.3.2 Nested Vectored Interrupt Controller (NVIC) configuration") is rather vaguely pointing in the direction of ARM's website for full documentation. I wasn't able to figure out if there is a default interrupt handler set up (at boot) for flash errors.
  • You've only done erases at sector level manually, so try to manually (as in by writing the appropriate register yourself) issue a full flash erase command; the only way to do this in a single command seems to be the "Unsecure flash command" documented in section 18.3.9.10 (p. 246) of the manual. This will both "unsecure" the device and do a full flash and EEPROM erase. You can poll a FSTAT bit (CCIF) to see when it's supposedly completed and check the error flags again afterwards. EDIT: there's also a "18.3.9.7 Erase All Blocks command" section in the manual, duh.
  • try a lower bus clock frequency. Anything above 0.8 Mhz works according to the documentation. I'm suggesting this because there was one thread on the Freescale forum where an external flash worked fine, but not above a certain frequency that still was in the ok-documented range. So it's possible that the flash controller in the chip is flakey and cannot operate on the full range of stated frequencies.
  • likewise, thy a different chip. It's not inconceivable that given how much these cost (around $3) you've got a bad one. I do remember having an embedded x86 chip that worked fine in most ways but had weird errors on certain protected mode instructions; my problem went away with a different device of the same make. It's not clear to me if Freescale has (publicly stated) steppings and errata for these devices or not.
This is all I can think of in terms of debugging suggestions that wasn't said by others on this page.
20150103 edit(s):
(Moved material here from my comments & expanded)
It seems that not all Kinetis Series are (officially, at least) tested with all flashers. The fairly new EA series that you're actually using appears to be officially supported only by Freescale's own/OEM Cyclone MAX flasher; it's the only one listed on Freescale's page for the EA serires. Now granted, for older Kinetis like KL0 the list is much longer, including a SEGGER. I don't know if that's simply because of a lack of testing of other flashers for the EA series or if there's actually some programming quirk involved that only their Cyclone MAX currently knows about. I was hoping that maybe this is just Freescale being slow on listing other flashers, but upon checking the J-link manual (hopefully the right one), there's no Kinetis E or EA series listed there (p. 249) as tested either, but only Kinetis K10 to K60 devices (and some older MAC7's).
Worth noting is that the PExDrv software/firmware for the Cyclone MAX has a service pack (v10.3) dated 3/20/2014, which "Adds support for MKE04Z64, MKE04Z128, MKE06Z64, MKE06Z128, SKEAZ64 and SKEAZ128 derivatives." Another clue is that Freescale's own open-source bootloader/flashloader software for the Kinetis, despite being updated even more recently in 12/2014, does not list any E or EA [sub]series devices as supported. So I think there's something sufficiently different regarding flashing between the E/EA-series and other Kinetis like the K10, although I have no idea what exactly is that difference. Therefore I think that expecting EA flashing to work automatically with anything but the Cyclone MAX is probably unrealistic at this point. You might be able to eventually figure out how to do it at "bare metal" level (direct register commands) from the EA-series documentation, but I agree that the documentation is pretty obtuse; it certainly lacks any step-by-step instructions being just a reference manual. Had Freescale's open-source bootloader/flashloader supported the E/EA series, you'd have been able to peek at its source code and reproduce its steps... but that's alas not an option.
Your experiment with the FRDM-KL25Z (which comes with a Kinetis L series) points in the same direction, i.e. you can't swap an L-series with an EA-series and use the same flasher (OpenSDA in this case).
And if you're like Keith (the blogger) who "think[s] $100 dollars for a programmer is ridiculous", you probably won't be pleased with the perspective of dropping $900+ on that Cyclone. I don't know if Freescale does this on purpose to fleece their automotive customers or what... It surely looks odd that the tooling for most of the Kinetis series doesn't work with the E/EA.
Also beware that OpenSDA's flashing function only works under MS Windows, apparently.
If you're willing to try (hacking) more boards, one with an E-series Kinetis might a better idea, e.g. FRDM-KE02Z ($13 at Digi-Key); also uses OpenSDA so it might be hackable. They don't make/sell boards with the EA-series, as far as I can tell. However, it seems you cannot use one OpenSDA processor/board to program a different Kinetis type than the one on its own board, even if both processors are in the same (e.g. L) series, but different numbers. Unfortunately "Open" in OpenSDA only means the SDA spec is open, not that they give out the source code as open-source; so I can't even find source code to program an E-series flash. Apparently, I'm only half-right about that. OpenSDA v1 is not open-source, but v2 is.
So here's the lowdown on OpenSDAv2. It's basically just a CMSIS-DAP/mbed bootloader & flasher. So it may not have the same features or support the same chips as v1... and that actually turns out to be the case because flash_features.h does not list any MKE (Kinetis E-series) let alone SKE (EA-series) devices. In summary, Freescale's proposition for the EA series seem to be: buy our $900 Cyclone flasher or good luck writing your own from whatever incomplete bits of open source we have released.
It turns out however that there is an open source project that can program at least the E-series Kinetis, namely USBDM. The relevant bit from its changelog is:
V4.1.6.140 (April 2014)
Additional Kinetis devices (MKE04, MKE06, MK64F)
  • Fixes for MKE devices (failed to program except after Mass Erase)
And based on that log entry, it surely appears the E-series are quirky. There's no direct support for EA-series (SKE), but that code base is probably your best bet if you want to hack your own flasher; or perhaps you can convince USBDM's author to add EA-series (SKE) support. As hardware for USBDM it turns out you can use the FRDM-KL25Z you've alreadly acquired; but you still have to hack the USBDM software to support the SKE chips.
The master config file for USBDM looks rather daunting. In USDBM different flashers (code bases) are used for different MKE series devices: something called "FTMRE" is used for MKE04 & MKE06, but "FTMRH" is used for MKE02. After looking myself briefly at the two code bases, you almost surely want the FTRMH code base not the FTRME one. The latter has a different FTMRH structure than your SKEA64 device, for example, the clock divider is not the first but the 4th field. FTRME also sets the bus FIDV to 0x17 = 24Mhz, which seems out of range for your chip (p. 224 in the KEA64 manual suggests max 20Mhz). FTMRH sets it to 0x0F = 16Mhz (like you do), which seems okay.
At this point, (unless you wanna buy the Cyclone MAX) your best bet is to contact Podonoghue to get your chip working with his code base. He seems active and quite willing to help with new devices (on the freescale forum).
Also from that USDBM source code I can prophesy that there's no way your SEGGER can correctly flash your SKEA by itself unless it gets its own firmware update first. Why do I say that? Because USDBM's FTMRH code base is used by exactly one device there, the MKE02, which your SEGGER seems to know nothing about either (based on its manual). Other, more common devices like the Kinetis L and K series use a different USDBM flasher based on a "FTFA" code base. If you look at FTFA's code, the flash controller register structure (also starting at 0x40020000) is different for these; the first field isn't even a clock divider, but the stat register, etc. "Great" way for Freescale to make incompatible devices... but a boon for flasher-makers, no doubt.
    \$\begingroup\$ FERSTAT doesn't show anything useful as you suspected; I'd tried it early on in this whole debacle. All the flash interrupts are disabled by default, but I did check to see if this was perhaps part of the problem. No dice there either. I do have two boards and they both act the same way but I've learned over the years that it's a vanishingly small amount of time that silicon is actually to blame, which is why I'm tearing my hair out here. :-) \$\endgroup\$
    – akohlsmith
    Jan 3, 2015 at 5:08
  • \$\begingroup\$ I'll try dropping the frequency; the defaults out of reset seem to be for a 16.78MHz bus clock (32kHz * 1024 / 2), which is why I selected a flash clock divider of 0x10 (32kHz * 1024 / 2 / 16 is 1.048MHz which is within spec but perhaps a little close to the edge) \$\endgroup\$
    – akohlsmith
    Jan 3, 2015 at 5:12
    \$\begingroup\$ Your other suggestion, about the unprotect command (0xb) instead of erase all (0x8) ... it succeeds, but I can't stop the CPU afterward and I can't seem to program anything into flash afterward either. \$\endgroup\$
    – akohlsmith
    Jan 3, 2015 at 5:12
  • \$\begingroup\$ I do thank you profusely for all of your effort in trying to help this internet stranger. I'm struggling to understand why this chip is so very hard to use, even when using supported programmers (J-Link and CMSIS-DAP) and Freescale's own development environment and tools. It's blowing my mind. \$\endgroup\$
    – akohlsmith
    Jan 3, 2015 at 5:14
  • \$\begingroup\$ Thank you for your detailed research and continuing help. In fact this is exactly what I ended up doing: using the FRDM-KL25Z with the USBDM firmware and standalone ARM flasher. This is what got my blinking LED test into the device. What is curious is that the Segger supported CPU list explicitly mentions the SKEAZN64xxx2, but it doesn't work. \$\endgroup\$
    – akohlsmith
    Jan 4, 2015 at 15:43
Did you try this: Unlocking and Erasing FLASH with Segger J-Link
Allegedly you have to:
In order to re-program the protected FLASH sectors with Segger J-Link, I need first to unlock and mass erase the device. For this, there is the J-Link Commander utility which has a command line interface to unprotect and erase the device. For erasing only, the J-Flash (and Lite) is a very useful tool, especially to get a ‘clean’ device memory.
What I found interesting is that you have to unlock it and erase it in the next step if you want the unlock to be permanent:
But it seems that I need to do an unlock, followed by an erase to make it permanent. To erase the device, I can use the same command line utility. But I need to specify the device name first, and then I can erase it (example for the KL25Z):
EDIT1: added wrong data.
EDIT2: can you perhaps read the Flash Security (FSEC) register? Did you try?
EDIT3: from Using the Kinetis Security and Flash Protection Features, Rev. 1, 6/2012
Mass erase via Debugger/JTAG Debuggers and JTAG tools have very limited access to the device when a processor is secured. The only registers that can be accessed through the JTAG are the MDM-AP Status and Control registers. In order to allow debug tools to unsecure parts, bit 0 of the MDM-AP Control register can be set to request a mass erase of the processor. In order to use this method to disable security, FSEC[MEEN] must be set to a value other than 10 to allow mass erase capability. If the mass erase is disabled, FSEC[MEEN] = 10, then the mass erase request will be ignored by the flash and the device cannot be unsecured using this method. Many debuggers will automatically use bit 2 of the MDM-AP Status register to determine if a device is secured when attempting to establish a connection. A debugger pop-up window might be used to alert that the device is secured and ask if a mass erase is desired to unsecure the device. Once the mass erase is completed and verified, security will be disabled. Some debuggers might automatically program the flash configuration field to put the flash into an unsecured state after the mass erase completes, FSEC = 0xFE.
Also I stumbled across a posts mentioning different kinetis families require different RESET signal manipulations when trying to read/write the MDM-AP register.
EDIT4: did you try adding a strong pull-up on SWD_DIO? It's a shot in the dark, but Freescale recomends it.
  • \$\begingroup\$ Thank you for taking the time to help cross-check and make suggestions. FTMRH_FSEC (0x40020001) returns a value of 0xfe, which is as unlocked/insecure as you can get. If I read flash at 0x0000400c I can also see the security bits showing the same value (which is where FSEC gets the values on power-on reset): J-Link> mem8 400 10 00000400 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FE FF \$\endgroup\$
    – akohlsmith
    Jan 3, 2015 at 16:09
  • \$\begingroup\$ J-Link has a "rsettype" command with a specific Kinetis value (6) which disables the watchdog timer on reset. It doesn't halt the processor, but I can do that with the "h" command. I can also see that if I don't use rsettype 6 that the watchdog registers report that the watchdog is enabled, which coincides with the documentation. \$\endgroup\$
    – akohlsmith
    Jan 3, 2015 at 16:14
  • \$\begingroup\$ I would try the pull-up, both boards you tried do not have it and if this does not work, then the Jlink is NOK. \$\endgroup\$
    – iggy
    Jan 3, 2015 at 16:22
  • \$\begingroup\$ I tried the pullup (4.7k, not sure how "strong" strong should be) but it didn't make any difference. \$\endgroup\$
    – akohlsmith
    Jan 4, 2015 at 1:22
  • \$\begingroup\$ 4k7 is fine. You did all you could. From this point on verify behaviour with FRDM-KL25Z and then send 1 million tickets to the Jlink guys. \$\endgroup\$
    – iggy
    Jan 4, 2015 at 14:25
You have to halt the processor first. It is obvious that you get a symptom of a running processor. I use openocd; before flashing the device I use "reset halt" command. That "halt" is a subcommand of "reset", for halting immediately after reset, while there is a standalone halt command too.
So look for a "reset halt" command, just a halt won't be enough because you have to get to state of pre-initialization of vectors I guess.
  • \$\begingroup\$ Thank you for your comment, but the segger does halt the cpu first. I've also tried manually halting the cpu before issuing these commands without any change. I should have made that obvious in my question. \$\endgroup\$
    – akohlsmith
    Dec 31, 2014 at 12:55
  • \$\begingroup\$ I didn't notice you were saying that a halt before the initialization of the vectors might be necessary. Looking into it, but I'm having trouble understanding why that would be necessary. Thank you for the hint, every bit helps \$\endgroup\$
    – akohlsmith
    Dec 31, 2014 at 14:45
I haven't seen it mentioned yet, so I'll go ahead and speculate that the problem is that this part has a cache that is enabled on reset. This is consistent with the "weird" behavior you observed with the blank check. The underlying Flash was updated but the cache was not. To fix this, turn off both the data and instruction cache by writing to MCM_PLACR at F000_300Ch and also clear the cache as you do so. This same weird behavior is likely to have confused the Segger as well.
  • \$\begingroup\$ This was a very good suggestion. on reset, MCM_PLACR reads as 0x00000850, which is a little odd (data cache disabled, but bits 6 and 4 are reserved in the documentation). I attempted to disable everything (speculation, controller cache, instruction caching) and then clearing cache by writing 0x0000bc00; it read back 0x0000b850 but no change in behaviour. \$\endgroup\$
    – akohlsmith
    Jan 3, 2015 at 16:03
  • \$\begingroup\$ I'm going to be very interested in hearing when you do finally solve this problem. Meanwhile, this chip is certainly not going to be in any of my designs any time soon. Sorry for your pain, but thanks for sharing the interesting question. \$\endgroup\$
    – Edward
    Jan 3, 2015 at 17:16
Since the error message is about the PC value, it sounds like the CPU is going off the rails somewhere. This is a long shot, but have you tried disabling the watchdog timer?
  • \$\begingroup\$ That was an EXCELLENT suggestion; I spent some time after reading your answer testing this theory. It appears, however, that when running "device skeazn64xxx2" that the J-Link already takes this into account and disables the watchdog after resetting. I verified this by checking the WDOG_CS1 register both with and without specifying the device between power cycles. :-( \$\endgroup\$
    – akohlsmith
    Dec 31, 2014 at 17:24
  • \$\begingroup\$ Hmm… okay, the other thing I noticed is that you're getting in correctable errors during the blank check. Is your J-Link disabling flash ECC? If not, that could cause trouble with read-back verification and maybe even trigger unexpected interrupts. (I'm not familiar with Freescale MCUs specifically, but I think this sort of behavior is pretty common.) \$\endgroup\$
    – Adam Haun
    Dec 31, 2014 at 17:43
