I am designing a project that contains several CMOS counter ICs (CD4017 specifically).
What is the state of the counter on power-on? Do I have to incorporate circuitry that pulls the reset pin high on power-on to ensure the counter starts at zero?
I checked datasheets from multiple manufacturers, and none of them mention this subject. I found several claims online that the state of the counter is unpredictable on power-on. However, I also found many projects which do not include a reset circuit, and the issue is not mentioned either.
The reset circuit adds complexity and additional parts, which I would like to avoid if they are unnecessary.
You have to assume that if the datasheet doesn't specifically mention a power-on state, that the state of any digital logic is undefined at power-on, and you need to provide a reset pulse to get it to a known initial state.
Generally speaking, only single-chip microcontrollers implicitly handle power-up initialization. However, you can purchase tiny power-up/reset controller chips that will add that feature to any circuit.
The initial state of most digital counters is unspecified. If your design requires the counter to start at zero, you must "manually" clear the counter after power-up.
In many applications the initial state of a counter is not important, as it will soon be reset during normal operation.
    \$\begingroup\$ It may be worth noting that datasheets for non-binary counters sometimes specify count sequences from every state; something like a BCD counter might normally never go more than 9 pulses without reaching "9", but if it happened to start on "A" it might count A-B-C-D-0-1-2, etc. needing a total of 13 counts before the first time it reaches "9". Some kinds of counters if not reset might get stuck in a cycle which never reaches an "expected" count value. \$\endgroup\$ – supercat Dec 29 '14 at 18:25
