I am working on a hobby project that I want to power with a LiPo Cell battery which provides 3.7v with a max of 2A output. I need to power a 5v peripheral that has varying current draw up to the 1A-1.2A range. In this case it seems I could use a TPS61200 switching regulator or a TPS61090. I am leaning toward the latter because I could really use 96% efficiency (vs 90% on the TPS61200) and the low battery indication, but I was wondering if there was any reason to use the TPS61200 in this case?
No, the TPS61090 will allow you to get more efficiency and higher output current. You don't need the TPS61200's ability to run at very low input voltages. The TPS61200 is in a smaller 3mm x 3mm package vs. 4mm x 4mm for the TPS61090, but you didn't mention space being an issue.
  • \$\begingroup\$ Space isn't an issue in this case. \$\endgroup\$
    – Nate
    Commented Jan 2, 2015 at 21:54
