I'm trying to set up a U-blox 6 GPS module with an Arduino.
In order to save power I have tried to reconfigure it using the U center to search for a fix only once every 5 minutes. I have read the instructions however probably I don't understand them correctly as the GPS still seems to give a reading for latitude and longitude once every second. I would like to know why this is and what I am doing wrong if someone could tell me.
The settings I used are:
Update Period: 300
Search Period: 150
Grid Offset: 0
Acquisition Timeout: 60
On Time:2
While the GPS itself is actually stationary I get results that are changing slightly e.g. as follows from 10:41:24:
$GPGLL,4119.01373,S,17445.96088,E,104124.00,A,A*71 10:41:25
$GPGLL,4119.01371,S,17445.96091,E,104125.00,A,A*7A 10:41:26
$GPGLL,4119.01373,S,17445.96100,E,104126.00,A,A*72 10:41:27
$GPGLL,4119.01371,S,17445.96102,E,104127.00,A,A*73 10:41:28
$GPGLL,4119.01380,S,17445.96110,E,104128.00,A,A*71 10:41:29
$GPGLL,4119.01380,S,17445.96112,E,104129.00,A,A*72 10:41:30
$GPGLL,4119.01380,S,17445.96112,E,104130.00,A,A*7A 10:41:31
$GPGLL,4119.01392,S,17445.96120,E,104131.00,A,A*79 10:41:32
  • \$\begingroup\$ Over that five minutes does the position change at all? It's been a while since I've used a U-Blox but I thought there were different parameters for how often the fix was calculated versus the output rate. \$\endgroup\$
    – PeterJ
    Commented Dec 31, 2014 at 10:27
  • \$\begingroup\$ thanks, yes it does seem to be changing slightly e.g. as follows 10:41:24 $GPGLL,4119.01373,S,17445.96088,E,104124.00,A,A*71 10:41:25 $GPGLL,4119.01371,S,17445.96091,E,104125.00,A,A*7A 10:41:26 $GPGLL,4119.01373,S,17445.96100,E,104126.00,A,A*72 10:41:27 $GPGLL,4119.01371,S,17445.96102,E,104127.00,A,A*73 10:41:28 $GPGLL,4119.01380,S,17445.96110,E,104128.00,A,A*71 10:41:29 $GPGLL,4119.01380,S,17445.96112,E,104129.00,A,A*72 10:41:30 $GPGLL,4119.01380,S,17445.96112,E,104130.00,A,A*7A 10:41:31 $GPGLL,4119.01392,S,17445.96120,E,104131.00,A,A*79 10:41:32 \$\endgroup\$
    – Shara
    Commented Dec 31, 2014 at 10:43
  • \$\begingroup\$ the GPS itself is actually stationary \$\endgroup\$
    – Shara
    Commented Dec 31, 2014 at 10:50
  • \$\begingroup\$ I've just added the info from your comments to the question. I'm heading off soon but if you don't get an answer meanwhile I'll have a better look tomorrow, I think I've got some code somewhere that changes the update period and seem to remember there was some subtle trick. \$\endgroup\$
    – PeterJ
    Commented Dec 31, 2014 at 10:58
I think I've found the problem now...
In the U-blox center Configuration View I changed the settings in the section:
RXM (Receiver Manager) from 0-Continuous Mode to 1-Power Save mode.
Now it seems to be collecting points only once every 5 minutes as expected :)
