-1
I'd like to configure a circuit to replace two LEDs (one red, one green) which illuminate alternately with one bicolor LED.
There are three leads for the remote LEDs. I'm suspecting there is a common ground or a common power.
If all else fails, I like the suggestion to use an LED with a clear case, and the mount other LED behind it. Nice low-tech solution!
The manufacturer has provided the attached schematic for the two-LED circuit. Can anyone help with how I convert this for a bi-color LED which changes color by reversing polarity (one cathode anode anode):
    \$\begingroup\$ We're going to need to see a schematic. \$\endgroup\$ – Ignacio Vazquez-Abrams Jan 1 '15 at 19:21
For example if you want to build something like a model railroad crossing signal, you could design what's called a relaxation oscillator with a 74HC14 hex inverter, a resistor and a capacitor.
This will make a square-wave output and can drive the one die in the dual-color LED. To drive the other die in the LED, feed the output of the one inverter to (you guessed it) the input of another inverter. The output of the second inverter will drive the second die of the dual-color LED. This means that when the one LED die is on, the other will be off so they do not illuminate at the same time.
For some background material for the hobbyist, check out Forrest Mims books. He has a lot of cookbook circuits for things like this.
| improve this answer | |
There are two kinds of bi-color LEDs, common-anode and common-cathode.
If the two LEDs in the circuit share a common ground, or common power connection, then it might be as simple as replacing the two single LEDs with one bi-color, and wiring up. No actual circuit involved.
If they aren't common in any way, like one for AC On and the other for Current Limit, for example, or if they're not just LEDs but have internal resistors for direct operation from 12V or something, then you might need a circuit. You need to do some investigation and post more details here.
A trick, if this is a one-off modification, is to use a clear package LED for one of them, put it through the hole and attach the other one right behind it with clear glue. Then the red light shines out of the clear package of the green LED. This might be good enough in your application.
  • \$\begingroup\$ I've seen a third kind of bicolor LED: bipolar. The color is selected based on the supply polarity. (Internally, they're basically two LEDs in parallel, in opposite directions.) \$\endgroup\$ – duskwuff -inactive- Jun 20 '15 at 21:13
