Attached pictures are a lifted power pad+trace of a 1000W PSU of a commercial subwoofer. Caliper showed 0.42mm thick, which if correct gives about 12oz copper trace!
enter image description here enter image description here enter image description here enter image description here
In this particular pad was the source of a mosfet after rectifier bridge, transformer and capacitors bank.
Pad+trace are intact, I just need to reliably fix them back to place.
What are the best options? Epoxy? Maybe araldite? I am not sure if it will ever corrode copper or sensitive electronics.
Epoxy should be a great choice. I would tape the back of the circuit board so that the epoxy can go in the hole and self-level, put the epoxy in, and then use tape to hold the trace down.
After that, you'll need to re-drill the hole for the replacement component. The existing hole was probably plated through; if it was, you will need to solder the component onto both the top and bottom traces.
  • \$\begingroup\$ Mechanically I also think one can't go better. Now, are you sure that epoxy won't corrode anything? \$\endgroup\$ – tfm Jan 2 '15 at 5:06
    \$\begingroup\$ @tfm it looks like the vias have separated also. you may need to feed a wire through and solder it on both sides after you're done. \$\endgroup\$ – kolosy Jan 2 '15 at 5:24
  • \$\begingroup\$ Folks, anybody else? Epoxy corroding copper or electronics? \$\endgroup\$ – tfm Jan 3 '15 at 0:18
