I am tring to program the ADF4158 PLL Synthesizer with SPARTAN 6 FPGA using Microboard LX9. I studied VHDL for a semster 4 years earlier, and no practical use after that. So I need some experts suggestion to refresh my knowledge and acheive my goal. Below is the block diagram to explain my goal.
I am planning to use the PC to write the REGISTER values for the ADF4158 to a IO Buffer using a GUI tool as the register settings are very complex. Microblaze is the main controller, that sets a Enable signal HIGH for the SENDER block to copy the REGISTER values to the ADF4158, when the IO buffer write by the PC is over. The ADF4158 have 8 registers each with 32 bits. Below is the block diagram of the SENDER block:
The ADF4158 uses a particular timing sequence to tranfer the values to the 8 Registers. The value for the desired register is identified by the LSB of the 32 bit data of each register bit sequence. The Select Line needs to be toggled after each register data transfer. Image above.
Below is the code I wrote to establish the desired goal:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity Sender is
Port ( SS : out STD_LOGIC := 1;
CLK : in STD_LOGIC;
MOSI : out STD_LOGIC_VECTOR(31 downto 0);
Enable : in STD_LOGIC;
Data_IN : in STD_LOGIC_VECTOR(31 downto 0));
end Sender;
architecture Behavioral of Sender is
variable counter : integer := 0;
variable bitCount : integer := 0;
begin
process(CLK, Enable)
begin
if rising_edge(CLK) and Enable = '1' then
if(bitCount < 320) ---check to avoid 320 bit out of bound
if (counter < 32) ---counter to toggle SS after every 32 bits
SS <= 0;
MOSI <= DataIN(bitCount);
counter <= counter + 1;
bitCount <= bitCount+ 1;
else
SS <= 1;
counter <= 0;
end if;
end if;
end if;
end process;
end Behavioral;
Now my question is, I want the SENDER to read the data from the IO Buffer and send to the ADF4158 device. How to I sent up the connection, or is it possible to code to read a IO Buffer with a defined address? This location of IO buffer is the one where the PC will store data. I am not sure if the code I wrote is correct, so i would warly welcome any suggestions for modification.
