How do I connect the edge connectors on the PCB (shown in the below image) to a breadboard ? Are there any standard breakout boards or Adaptors available for this purpose ?
Link to the user guide of the PCB
I actually have one of these, and it is meant to be just an evaluation board, so you aren't going to find any standard mounting setup. I just used 30 AWG wire soldered from the board to my circuit.
These connections are meant to be breakouts that you can connect to a test board by soldering wires. I think they are 0.1" spaced, but because of the way they are using only 1/2 of a hole, I would be careful not to put any mechanical force on those connections. Big thick wires or connectors could fairly easily remove those pads if lateral forces were applied.
|improve this answer|||||
Generally with devices like this, these are meant to be surface mounted onto your application board so there won't be a standard socket you can just pop this into. Interesting that this has a USB connector because of that.
You can make it bread-board friendly by soldering a couple of sturdy wires or headers to the edge connectors. If they are .1" spaced, then you are in luck because you can use a similar header which will make it look much cleaner.
