I need to wire the following three-axis axis accelerometer:
http://docs-europe.electrocomponents.com/webdocs/127c/0900766b8127c68c.pdf
Here when I click on ADXL335, the below link comes with some more information: http://www.analog.com/en/mems-sensors/mems-inertial-sensors/adxl335/products/product.html
Here it says: Single-supply operation 1.8 V to 3.6 V
I have 3 problems here:
1) Is COM the common ground for Vs and X,Y,Z outputs?
2) What is ST pin for? I couldn't figure out what it is used for?
3) Should the power supply be constant? Can I use a battery? The reason I am asking these if I have 9V constant power supply and I use 3 resistors to make a voltage divider, would it be ok?
4) How can I extend that 6-pin, 0.1 inch spaced header? Is there generic plug name?
Yes, the evaluation board schematic shows the output filter capacitors from X, Y, and Z to COM.
Self test, check the datasheet, you probably don't need it.
No, use a proper regulator. See this question.
That is about as generic a termination as you can get. Find yourself something through hole with .1" pitch on your favorite distributor's website. Look at Molex and Amphenol for a locking header and connector.
  • \$\begingroup\$ thanks one thing about the voltage regulation. should i buy a voltage regulator such as:upload.wikimedia.org/wikipedia/commons/c/ce/… or if i would have an adjustable ac/dc adapter would it work? \$\endgroup\$
    – user16307
    Jan 6, 2015 at 19:10
  • \$\begingroup\$ Take a look at the LM317. That's a good part to have in your box. \$\endgroup\$
    – Matt Young
    Jan 6, 2015 at 19:12
