7
For example, the passband of a LC resonant circuit is the differences of frequency at +3db and -3db.
Why do we prefer dB?
  • \$\begingroup\$ the "3 dB point" is actually 10⋅log10(1/2) = -3.0102999566398... dB. It's chosen because 1/2 power is exactly where the asymptotes meet if you plot it on a log-log plot (I believe). \$\endgroup\$
    – endolith
    May 29 '11 at 18:16
    \$\begingroup\$ dB doesn't represent the difference, but rather the ratio. It is another way to write percentage. For an attenuator, "power reduced to 50%" and "power reduced by 3dB" mean the same thing, but put two attenuators in series and 3dB + 3dB is easier to computer than 50% * 50%. \$\endgroup\$
    – markrages
    Jun 2 '11 at 22:33
  • \$\begingroup\$ Neper (Np) is pretty common too, especially in RF engineering. Neper's are like dB's, though based on ln(value) instead of 20.log(value). \$\endgroup\$
    – jippie
    Oct 18 '12 at 19:16
13
Many processes in nature are either of logarithmic nature (like human senses) or have a great dynamic range.
Describing them on a logarithmic scale and expressing differences in dB has several advantages:
  • often the absolute difference doesn't matter, but the ratio (that's what dB is used for) does (e.g. signal-to-noise ratio)
  • smaller numbers can be used
  • there's an approximately linear relation between measurement and perceived sensation
  • chained attenuations or amplifications can be expressed by addition instead of multiplication (easier to calculate in the head)
Here's another video about it.
In many cases, voltage ratios are expressed in terms of dB rather than absolute numbers because there are many relationships which end up being linear when expressed in terms of dB. It is simpler, for example, to say that an N-stage low-pass filter will attenuate frequencies above the cutoff by \$(6 \times N) \frac{dB}{octave}\$ than it is to say that it will attenuate frequencies above the cutoff by a ratio of \$({\frac{f_c}{f}})^N\$.
  • \$\begingroup\$ Right idea, but mixing two concepts. First, dB is a ratio relative to some reference, not an absolute value. Second, as you point out, it's a logarithmic representation of that ratio rather than a linear one. \$\endgroup\$ May 30 '11 at 18:18
  • \$\begingroup\$ @Chris Stratton: By "absolute number" I didn't mean an absolute quantity, but rather a "bare" number without a dB suffix, as distinct from one with such a suffix. I should also have mentioned that it's easier to compare things that attenuate by 40, 50, 60, and 120dB than things which scale a signal by 0.01, 0.0033, and 0.001, and 0.000001. \$\endgroup\$
    – supercat
    May 31 '11 at 16:21
  • \$\begingroup\$ the word you want is 'linear' not 'absolute' \$\endgroup\$ May 31 '11 at 16:31
dB is useful since it is a relative expression. +/-3dB is a doubling or halving of power.
dB are often used because the human senses have a logarithmic response, to increase the dynamic range.
Around 3dB gives a sensation of doubling or halving the stimulus, as well as doubling or halving the physical value. That value seems to apply to all human senses, and is one reason why 3dB is so ubiquitous. Psychophysics, a branch of experimental psychology, has a long history of investigating this stuff. The minimal amount of change that can be detected is around 1dB (the Just Noticeable Difference or JND). 0dB is the absolute threshold, below which the stimulus isn't detected.
  • \$\begingroup\$ do you mean the change of voice? \$\endgroup\$
    – Jichao
    May 29 '11 at 18:14
    \$\begingroup\$ "0dB is the absolute threshold, below which the stimulus isn't detected." What do you mean by this? 0 dB is by definition a ratio of 1 - ie, no change. Do you perhaps mean 0 dB relative to some reference power? \$\endgroup\$ May 30 '11 at 7:44
    \$\begingroup\$ @Chris - it's not 0 dB relative to some reference, but 0 dB as a reference. We talk about sound levels of 90 dB, but that's always compared to some other level. Which is the 0 dB level. There are several dB scales each with its own reference. On the dBm scale for instance 0 dB is 775mV in 600 Ohm, or 1 mW. \$\endgroup\$
    – stevenvh
    May 30 '11 at 9:50
    \$\begingroup\$ @stevenh If you talk aboout 0dB as a reference, you are mis-speaking. dB is always a ratio, relative to some reference. "x dBm" is a power stated by its ratio to a milliwat, but "x dB" is only a ratio, since no reference is given. You must give a reference to state a power logarithmically. \$\endgroup\$ May 30 '11 at 15:29
    \$\begingroup\$ @stevenh "Everybody working with dBm knows what this reference is" yes, they know what the reference is because the 'm' in 'dBm' refers to the milliwatt reference. But if someone just says 'dB' there is no reference. You can perhaps argue that 'dB SPL' encodes a reference power in the definition of 'SPL' - but 'dB' by itself is a ratio, and it's improper to use it as a power. \$\endgroup\$ May 30 '11 at 18:11
