I'm speccing out some switches for a project... is this some standard notation I've never seen before?
Electrical Ratings: 12(4)A 250V AC
What does the (4) mean?
(Source)
  • \$\begingroup\$ Looks like the maximum current spec for inductive loads. \$\endgroup\$ Jan 8 '15 at 19:34
They may refer to the inductive load switching current as these can cause a higher than normal voltage and cause a longer arc at switch off. This will be less than the AC resistive load current that a switch or a relay can handle.
The data-sheet you indicate does not shed any light on the matter. A similar short-form data-sheet (link below) for the same (or close) part suggests that they can handle 16A at full voltage but only about 4A when a horsepower rating is specified, this would imply that motors (often rated in power instead of current) cannot use the full current capacity of the switch. This supports the theory that it is able to handle 12/16A resistive loads (filament lamps and heaters) and 4A inductive loads (motors, inverters and a lot of modern electronics with switching supplies) and is a common range of limits one can see in switches.
Most consumer mains AC switches that are rated for 125 or 250V AC are able to handle similar currents when switching DC but at about 10 to 20% of the rated voltage. This is due to the fact that a DC arc does not extinguish automatically at twice the line frequency and needs a larger contact gap. Sometimes a second voltage may be indicated in parenthesis and this would usually refer to the DC rating, the current limits would obey the same kind of limit as the higher voltage mains ratings limiting the power the switch can carry to much less than what can be switched by the same switch on the mains side of a step-down transformer.
http://html.alldatasheet.com/html-pdf/402125/CWIND/GTS448B101A1HR/157/1/GTS448B101A1HR.html
    \$\begingroup\$ Normally, it's the voltage rating that is reduced for DC vs. AC operation. But you may be right about the distinction between resistive and inductive AC loads. \$\endgroup\$
    – Dave Tweed
    Jan 8 '15 at 15:00
  • \$\begingroup\$ @DaveTweed Thank you, you are correct. I edited to make the distinction clearer. \$\endgroup\$
    – KalleMP
    Jan 8 '15 at 15:07
    \$\begingroup\$ Ok, looks like to be sure I'll have to check with the manufacturer. Will report if/when I hear back. \$\endgroup\$
    – glibdud
    Jan 8 '15 at 15:10
    \$\begingroup\$ Got it. From the manufacturer: "The (4) means an inductive or motor load rating at 4 amps." \$\endgroup\$
    – glibdud
    Jan 8 '15 at 18:19
Well, here is a similar rating from a different manufacturer in which the parenthesized current rating is for a motor load.
http://www.controlfr.com/marcas/marquardt/mq_catalog.pdf
You should definitely check with your manufacturer to ensure that the rating applies both to the type of load you have and also to the regulatory agency you have to deal with. If you need a 10A switch, there's no point having a switch rated to 12A if CSA or UL only think it's good for 8A (and you need CSA's or UL's blessing to be able to sell the device).
