I've seen many devices with spade-like connectors (DC Jacks, AV connectors, etc.) such as below:
The datasheet for the above connector has the follow pad layout:
However, there is no drill hole / line cutout on the pads. Is there a way in Eagle to specify a line cutout rather than a drill hole so the board house knows what to do?
Making drill holes makes it very hard for the solder to adhere onto the connector, because there are huge semi-circle gaps around the flat connector.
