I am working on a project on DC DC converters in which the concept of soft switching i.e, zero voltage switching (ZVS) and zero current switching (ZCS) are used. One method to attain this is using an edge resonant switched capacitor cell (ER-SWC) as specified in one of the IEEE Transactions published in 2013: Analysis, Design, and Performance Evaluations of an Edge-Resonant Switched Capacitor Cell-Assisted Soft-Switching PWM Boost DC–DC Converter and Its Interleaved Topology.
I have been trying to find out the significance of "edge resonance" but in vain. In all my findings I could only see the lines "edge resonance between the resonant inductor and the resonant capacitor" but nothing about what it is exactly and why it is so called. It would help me to justify why I should be using this concept for my converter if I knew what it meant.
enter image description here.
I am familiar with normal resonance occurring in an electrical RLC circuit but not edge resonance. On googling for the same, the results are based on some communication related topics and not electrical. I have seen the same question posted before by someone else but it has never been answered.
  • \$\begingroup\$ Not (yet) a texbook topic it seems, but see scholar.google.com/… \$\endgroup\$ Commented Jan 11, 2015 at 18:54
  • \$\begingroup\$ @NorinaSamson Just ignore Olin's excesses and treat him politely and you'll find him helpful and useful. He seems to be having a bad year so far. He does like people to dot their t's and cross their i's [ :-) ] and get their unit's right and spell correctly (even though he himself consistently misspells certain words) and capitalise and punctuate correctly and show due respects for one's putative betters and ... . BUT just when you think he's about in the same class as the kill-joy officious bald eagle on The Muppet Show, lo and behold, you suddenly find that he can be .. (wait for it) ... \$\endgroup\$
    – Russell McMahon
    Commented Jan 18, 2015 at 8:09
  • \$\begingroup\$ ... accommodating, helpful, almost even affable, willing to provide immense amounts of assistance, and knowledgeable as all get-out on just about everything electronic and electrical. He's actually quite a nice guy a large percentage of the time and it's probably better not to try to understand his predilection for rendered due respect and just do as well as you would with anyone else and things will be fine long term. \$\endgroup\$
    – Russell McMahon
    Commented Jan 18, 2015 at 8:11
  • \$\begingroup\$ Ah - I see that while I had those comments in preparation certain other ones went away. Mine may too in due course. Just take note as above for reference and the partying will be great :-). \$\endgroup\$
    – Russell McMahon
    Commented Jan 18, 2015 at 8:15
All circuits have parasitic inductance and capacitance. Nothing can really be done about that. But, it is possible to find ways to use the parasitic components to advantage in some cases. In power conversion it is sometimes possible to arrange things such that the transfer of energy from a parasitic inductor to capacitor results in greatly reduced switching losses in transistors and diodes.
The most simple example of edge resonance is a voltage step driven RLC with diode circuit.
You probably know that the Q of this circuit is \$\frac{Z_o}{\text{R1}}\$, and as long as R1 has a value that allow Q > 5, the circuit will be very under damped (highly resonant). If a step input is applied, voltage on C1 will ring up to ~ 2Vstep. At that time current in L1 will be zero. D1 blocks any discharge of C1. That's a resonant rising edge. Replace the diode with a well timed switch and you can get a resonant falling edge as well. This may seem a trivial example, but all edge resonance is based on the same dynamic.
H-bridges that have an inductive load and switch capacitance can use edge resonance for Zero Voltage Switching. Operational conditions can be narrow, restricting load and input range, for complete ZVS. Extra inductance or capacitance may have to be added to reach the proper condition for a given input voltage or load.
Also, the same resonance can be used to reduce high frequency spectral components for reduced noise and interference.
  • \$\begingroup\$ I'm not seeing a distinction in this answer between an edge-resonant converter and (simply) a resonant converter. The topologies considered edge-resonant in literature are more complex, involving an auxiliary switch. See my answer for ref. \$\endgroup\$ Commented Jan 24, 2015 at 6:40
  • \$\begingroup\$ @RespawnedFluff - Practical edge resonance does get very complicated. This answer was just to show, in simplest terms, an example of edge resonance, LRC circuit with diode to get a rising resonant edge. In edge resonance the circuit is driven far from resonance but well timed switches are used to allow resonant transitions. While resonant converters drive near resonance, using periodic switching to control resonant cycle, peak currents and voltages become much higher. \$\endgroup\$
    – user16497
    Commented Jan 24, 2015 at 17:31
Based solely on reading abstracts of papers, the term "edge resonant" seems to relate to snubber action occurring in a selected manner at switching edge in order to minimise energy losses - probably typically by implementing a mix of ZCS (zero current switching) and / or ZVS (Zero Voltage switching as appropriate to achieve the desired optimisation. Snubber triggering and/or switching appears to be based on some derived function of extant conditions rather than at an external time defined position.
For example:
This paper A novel pulse regenerative active auxiliary edge resonant bridge leg link soft commutation snubber and resonant snubber-assisted three phase soft switching sinewave PWM inverter specifically contrasts edge resonance snubbing and "hard switching". I do not have unpaid access to the paper but it seems likely that an examination of their comparison will explain the differences in method. They say -
  • The operation principle and operating characteristics of this active auxiliary snubber circuit are respectively described, together with the practical design procedure of this unique edge resonant snubber. Furthermore, the three phase soft switching sinewave PWM inverter with the novel auxiliary active edge resonant bridge leg link snubbers treated here is evaluated and discussed as compared with three phase hard switching sinewave PWM inverter
And this paper A Divided Voltage Half-Bridge High Frequency Soft-Switching PWM DC-DC Converter with High and Low Side DC Rail Active Edge Resonant Snubbers (apparently) associates the term with ZVS / ZCS snubber control. They say :
  • " ...All the active power switches in the half-bridge arm and dc bus lines can achieve ZCS turn-on and ZVS turn-off commutation operation and consequently the total turn-off switching losses can be significantly reduced. ..."
Similarly here:
Boost chopper-fed ZVS-PWM DC-DC converter with parasitic oscillation surge suppression-based auxiliary edge resonant snubber
  • " ... discussed and compared with the hard switching scheme from an experimental point of view. Finally, this paper proposes a practical method to suppress parasitic oscillation due to the active auxiliary resonant switch at ZCS turn-off mode transition with the aid of an additional lossless clamping diode loop, ... "
Well, from http://www.google.com/patents/US4912622 I found that an alternative term is transition-resonant converter. And this surely is textbook material, the general definition being "it employs resonant transitions only during the instants of switching". That seems to match what the circuit from your paper is doing (in this respect). It appears that "edge resonant" is a term preferred by researchers in Asian countries for some reason.
