I'm new to VHDL so I just have a question to ask about why this produces an error. I have an ALU defined in VHDL:
c <=        a + b       WHEN opc="0111"
ELSE        a - b       WHEN opc="1000"
ELSE        -a          WHEN opc="1011"
ELSE        -b          WHEN opc="0001"
ELSE        ABS(a)      WHEN opc="1110"
ELSE        ABS (b)     WHEN opc="1010"
ELSE        NOT a       WHEN opc="0010"
ELSE        NOT b       WHEN opc="1100"
ELSE        a AND b     WHEN opc="0100"
ELSE        a OR b      WHEN opc="0110"
ELSE        a XOR b     WHEN opc="0101"
(this is the architecture)
But then I want to make it synchronous,
PROCESS (clock)
BEGIN
    IF(rising_edge(clock)) THEN
        c <=        a + b       WHEN opc="0101"
        ELSE        a XOR b     WHEN opc="0111"
    END IF
END PROCESS;
This doesn't work, it comes up with various errors like:
';' expected.
Keyword "end" expected.
So I have now changed my code to:
PROCESS (clock)
BEGIN
        CASE opc IS
            WHEN "0101" => c <= a+b;
            WHEN "1000" => c <= a-b;
            WHEN "1011" => c <= -a;
            WHEN "0001" => c <= -b;
            WHEN "1110" => c <= ABS(a);
            WHEN "1010" => c <= ABS(b);
            WHEN "0010" => c <= NOT a;
            WHEN "1100" => c <= NOT b;
            WHEN "0100" => c <= a AND b;
            WHEN "0110" => c <= a OR b;
            WHEN "0111" => c <= a XOR b;
        END CASE;
    END IF;
END PROCESS;
And this doesn't produce any errors. But why does the original code which worked when put in a process not work unless I use the case statement?
Thanks in advance.
    \$\begingroup\$ The ternary operator c <= a when condition else b; is not allowed inside of process statements prior to VHDL-2008. SO you can enable VHDL-2008 support if your tool supports this or you use your later code example, which is much nicer :) \$\endgroup\$ – Paebbels Jan 12 '15 at 22:14
  • \$\begingroup\$ Paebbels is correct, and I have to add that if you are designing for ASIC or FPGA (specially) you should avoid nested If-Then-Elest statement. Also, at the end of your process add the "others" to make sure all the cases are covered with that statement. \$\endgroup\$ – FarhadA Jan 13 '15 at 9:30
  • \$\begingroup\$ Nitpick: conditional assignment is not exactly a "ternary operator", though it functions like one in this case. \$\endgroup\$ – fru1tbat Jan 14 '15 at 14:02
In order of effort:
  • If you have access to VHDL 2008 in your tools, enable it. If not, bug the vendor to support it!
  • add an extra signal calling c_sync and then add a line:
    c_sync <= c when rising_edge(clk);
  • Change your code to a set of if then statements.
| improve this answer | |
Your first try to make it synchronous didn't work because:
  • You haven't enabled VHDL 2008 (as stated in the other answers/comments)
  • the end of the conditional assignment is missing a ;
  • your END IF is missing a ;
Your second try works, because it doesn't require VHDL 2008:
The case-statement has been supported in processes since the first VHDL version, while the conditional assignment was previously forbidden inside processes (which has been changed with VHDL 2008).
