I am looking for the pinout on a hantronix HDM24216L-2-L3ES 24x1 LCD. I found the datasheet: http://www.hantronix.com/files/data/1278557021char-comm.pdf but I cant determine what the pinout is. Can someone help me find the pinout for this device?
The same page you got that datasheet from has another datasheet with the pin connections: http://www.hantronix.com/files/data/127855702124216l2.pdf You just had to select the data sheet and not the full spec. That full spec is also like, 10% of a full spec. Pretty sad documentation availability.
