I've salvaged a MOSPEC F12C20C Dual Power Rectifier from an old PSU. I've been looking for example circuits that would use this component, and an explanation of how it works but I've only found its datasheet and not much more.
If I understand correctly, its function is to rectify an AC current to make it DC, is that correct? How is this different from the typical diode bridge? (power dissipation capabilities maybe?)
According to the datasheet, this component is the equivalent of two diodes package together, is that so? If that's the case, how is it that it can achieve rectification with only two diodes and not the usual four?
Do you know of any example circuits I could build on a breadboard to test this component and play with it so I can better understand how it works?
Bonus: mine has the letters MNB next to the diodes schematic it has on it. Is it part of the name or is it just a serial number or something?
Thanks!
