I am designing a system to charge a single cell lithium battery. It requires pass-through, path-selection, over and under voltage protection. The bottom line is this system needs to power a device while unplugged, and continue powering it while it is plugged in charging the battery. This is for a research project, not any sort of commercializable product. It also has an expected lifetime of only about 3 weeks, so battery degradation isn't a huge deal. After trying numerous boards out from various suppliers, and even attempting to make our own we found one that almost works like we need it.
http://www.ebay.ca/itm/1-x-PCB-Li-ion-Lipo-Battery-3-7V-step-up-Convert-to-Output-Power-DC-5V-DLX-UPDC/130725341903?_trksid=p2050601.c100085.m2372&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140211132617%26meid%3D9d35d42468324327b2bb8abeed10b780%26pid%3D100085%26rk%3D4%26rkt%3D4%26mehot%3Dpp%26sd%3D181190701564%26clkid%3D3380855727044982483&_qi=RTM1963932
The problem is the pass-through current is too low, and the charging current is too low. Ideally we need something that works like a laptop where it continues to be powered whether it is charging or not. Right now it can output 1A maximum. We would like to double that to 2A if possible (or more up to 3A even).
With an approaching deadline is there a board available online that we are missing that does all this, or is there a modification/new design we can use to make this work?
Thanks for you help in advance!
  • \$\begingroup\$ Roughly how many units do you need, just one or a few? Not like 10 or 100 units? And what is the battery capacity (Amp-hours)? \$\endgroup\$
    – user57037
    Commented Jan 15, 2015 at 22:29
  • \$\begingroup\$ I only need a few units, less than 10. In terms of capacity, I'm looking at something between 5 to 10 Ah though we have batteries for up to 15Ah \$\endgroup\$
    – domknight
    Commented Jan 15, 2015 at 22:37
  • \$\begingroup\$ Would you consider buying an evaluation module from TI? I didn't look super carefully, but this one looks like it might work, and there are several others to choose from if you browse TI's website: ti.com/tool/bq24266evm-609 \$\endgroup\$
    – user57037
    Commented Jan 16, 2015 at 16:23
  • \$\begingroup\$ That board seems to be exactly what we need, we placed an order. Thanks! \$\endgroup\$
    – domknight
    Commented Jan 18, 2015 at 15:01
What you are trying to achieve does not seem overly hard but it needs to be better defined than has been done here so far because the situation that you describe sounds to be different enough than the usual charge & run situation that you need to make specific provisions.
You need to identify desired pass through Imax and I_pass_through_average for a given Ah capacity. The most demanding case will be that with the largest pass_through_Ah ratio.
Usually with simultaneous 'charge and run' situations I load is less or much less than Ichg_max. In such cases it is often OK to address the battery needs and accept that the load may somewhat prolong charging times. Clearly I_load_average must be less than I_charge_averge or the battery would never charge, but you may get situations where I_load is > I_charge for significant periods, or is a substantial fraction of I_Charge_terminate, and this will affect charging results.
Usually Imax in constant current mode Icc is the same in mA as the capacity in mAh. So a 1000 mAh cell is charge at 1000 mA max, a 5Ah cell at 5 A max etc.
If you just increase charging capacity without regard to interaction with charge termination you may 'have problems'. This is because LiIon/LiPo charging typically terminates when I charge in CV mode drops to some preselected percentage of ICC = Imax and I_pass_through is seen as part of Iterminate if special steps are not taken to prevent this.
Taking the extremes of your spec ie 3A charge and 5Ah cell that is 0.6C charge (still under the usual 1C max) the usual charging terminate current will usually be in the 0.5C to 0.1C range with 0.25C being typical. So here with a 5 Ah cell Iterminate will be 2.5 A / 1.25A / 0.5A max/typ/min. If I_pass_through is say 1A mean it will swamp a 0.5A terminate current and interact significantly with a 1.25A or even 2.5A terminate current. In a dumb charger, if the C/10 rate was used for terminate the charging would almost certainly never cease, at 1.25A terminate (C/4) it may cease on load dips and at 2.5A terminate charging may be prolonged.
A LiPo cell charged at CC of C/1 will reach about 75%-85% of full capacity when CV level of 4.2V is reached. If charging is at less than C/1 (as will be the case if you charge a 10 Ah cell at 5A or C/2) then an even larger % of the full capacity has been transferred when you reach 4.2V. If you are happy to accept say 90% of full capacity then the easy choice is to hard terminate charge when 4.2V is reached and have no CV final stage. This removes the need to make end of charge determinations based on combined pass through and CV currents. Some charger IC's are available with no CV stage.
Also, as now you only need a CC stage and a voltage cutoff at 4.2V then a current limited power supply and a comparator will fill your need. Adjustment of the current limit on an off the shelf supply may suffice in a small volume research situation.
