I currently have a 25 stage voltage doubler circuit I am using 50 0.1 uF x2 suppression capacitors, 50 1N4007 Diodes, and a 20 Mohm current limiting resistors at the final emitter stage. I am using 120 VAC as the initial input voltage.
I would like to increase my output voltage so I am interested in buying a higher value capacitor.
For example, if I upgrade to a 10 uF capacitor (100 times more powerful than current setup) will I need to change any other components of my circuit (e.g. the diodes)?
