I am using the AD835 to downconvert signals from around 1 kHz to around 10 Hz. While testing I found that the mixer behaves differently when using for example an LO at 1 MHz and RF at 999,99 kHz opposed to an LO at 1 kHz and RF at 1.01 kHz - both yield the same IF at 10 Hz, but have different amplitudes. Calculating the amplitudes using the given transfer function $$ W=\frac{(X_1-X_2)\cdot(Y_1-Y_2)}{U}+Z, $$ where \$X_1,X_2\$ and \$Y_1,Y_2\$ are either of the differential RF or LO inputs, \$U=1\$ and \$Z\$ an additive term set to zero in my case, I can not match the results (which of course should be equal regardless of the frequency range of the RF and LO as long as IF is the same)?! Just for convenience the equation I get out of this assuming two sinusoidal signals: $$ \frac{A_1\cdot A_2}{2\cdot U}\cdot \{[cos(\omega_1-\omega_2)t-\varphi]-[cos(\omega_1+\omega_2)t+\varphi]\} $$ with RF amplitude \$A_1\$ and frequency \$\omega_1\$, LO Amplitude \$A_2\$ and frequency \$\omega_2\$ and phase shift \$\varphi\$, if there is one (at first I generated both LO and RF with function generators with unknown phase shift, later I used a NI 6361 to generate signals with known phase shift).
While reading the datasheet again very thoroughly I noticed all plots being for frequencies starting in the MHz range. In general the mixers I find are designed for high frequency applications. In my opinion at least in theory there should not be a problem with low frequencies though.
So my question is: Is there any reason why this multiplier (and also others that specify the 3 dB maximum frequency and are wideband) should not work for low frequencies? If there are, are there recommendations for mixing devices or other approaches that fit my frequency range (from some kHz down to around 0-100 Hz)?
AD835 Datasheet
  • \$\begingroup\$ How much of a difference are you seeing? \$\endgroup\$
    – mng
    Jan 16, 2015 at 19:06
    \$\begingroup\$ Don't neglect that \$\omega_1 + \omega_2\$ term. When your signal and LO are at 1 MHz, that unwanted output term is at 2 MHz, but when they are at 1 kHz, the unwanted term is at 2 kHz, three orders of magnitude closer to your desired signal. How exactly are you filtering the output? \$\endgroup\$
    – Dave Tweed
    Jan 17, 2015 at 2:12
  • \$\begingroup\$ @ mng: I get differences ranging from -2 dB even up to -12 dB, depening on the frequency region. The maximum value in this cases is not at the expected IF frequency but slightly shifted. \$\endgroup\$
    – Irenaius
    Jan 19, 2015 at 7:37
  • \$\begingroup\$ @ Dave Tweed: I do not filter the output just yet, but since I evaluate using a AD converter card or a spectrum analyzer I do not think it would make a difference. \$\endgroup\$
    – Irenaius
    Jan 19, 2015 at 7:39
I haven't used the AD835, but I would expect it to work right down to DC. (That's easy to check) The two multipliers I have used (AD633 inexpensive*) and AD743 are lower frequency. As you know the output amplitude is very sensitive to the voltage level, so I'm going to guess that your amplitude difference may be do to layout and stray capacitance. Perhaps the 1 MHz is being attenuated somewhat. How big a difference do you see?
*if you can apply the term inexpensive to an analog multiplier.
  • \$\begingroup\$ The problem I had with the AD633 is the transfer function which includes a division by 10 whereas the AD835 has a divisor of 1 +/- 0.05. Regarding the AD 743 I do not see how you would use it as a multiplyer since it is a low noise OPA - could you give me a hint? \$\endgroup\$
    – Irenaius
    Jan 19, 2015 at 7:49
  • \$\begingroup\$ From the comments I take that there is no reason why the multiplyer should not work properly at low frequencies. I will try to alter the layout on a new PCB. I take it that the mistake is not in the multiplyer itself but in my application. \$\endgroup\$
    – Irenaius
    Jan 19, 2015 at 7:51
  • \$\begingroup\$ @Irenaius, oops, AD734. Your output signal is low at low frequency? 1 MHz is not really that fast..layout wise. What's driving the AD835? \$\endgroup\$ Jan 19, 2015 at 14:24
  • \$\begingroup\$ @ George Herold, my application is more 1 to maximal 5 kHz down to 0.1-120 Hz. Driving Signal is the output of an AD745 working as a charge amplifier for very small charges. So yes, I have very low amplitude signals at very low frequencies. \$\endgroup\$
    – Irenaius
    Jan 26, 2015 at 12:55
  • \$\begingroup\$ @Irenaius, How small? Maybe add some more gain before the multiplier? Gain is cheap. (Multipliers "like" big signals.) \$\endgroup\$ Jan 26, 2015 at 13:41
