I've just bought a PAM8403 pre-built circuit board for $1 on eBay, I was going to use it to drive a set of headphones but I neglected to consider that this is a Class D amplifier and will not take kindly to connecting the -ve output terminals together (since headphones are typically 3-wire, unless you have a set of very expensive balanced headphones).
So my question is, is there a cheap solution to connecting the two -ve terminals to drive a pair of headphones without rewiring the headphones themselves? In particular is there any arrangement of inductors and capacitors that will allow the negatives to be commoned?
I am aware that I can use two 1:1 Audio Isolation Transformers but the cheapest I can find these are about $5 each which is not ideal.
I have a feeling that it is possible to connect the two negatives together with some sort of LC filter but I'm thinking that it will probably greatly reduce the usable power output of the PAM8403 chip amp which is already quite low. I would like to hear anyone else's thoughts / ideas?
  • \$\begingroup\$ The datasheet says 3W. That isn't enough for you? In my experience, headphones are driven with milliwatts. You might be able to create a common ground after filtering, but since you only paid a dollar, and the PAM8403 is a loudspeaker amp and will probably not sound as good as a linear amp, maybe you should just scrap the whole idea. You could capacitively couple the two outputs, and that would at least provide DC isolation. But you would probably want to use 22uF caps, so that might still over-stress the class D outputs (effectively 10 uF load). \$\endgroup\$
    – mkeith
    Jan 18, 2015 at 8:23
    \$\begingroup\$ @mkeith it's 3W for a 4ohm load, typically headphones are up at the 32ohm mark so it will probably only give you about 375mW or so of power. It seems such a shame to scrap the amp, and I don't have any other use for it. There are LM4881 based headphone amps on eBay for just over $10 which are Class AB and would sound better but also cost more than 10x the price. Hmmm I was thinking of using caps but since there is essentially zero impedance between the two negatives (any they could be at the + and - rails respectively) I think it will probably destroy the amp. \$\endgroup\$
    – ALM865
    Jan 18, 2015 at 10:56
  • \$\begingroup\$ Maybe the isolation transformers are the only way to go? I might hang on to the amps and butcher some old electronics until I find a couple of 1:1 isolation transformers. Some old wall socket powered phones might have isolation transformers that could be used to do the trick... \$\endgroup\$
    – ALM865
    Jan 18, 2015 at 11:04
6
As mkeith says, it may not sound as clean as a linear amplifier, and you have to remember that headphones are a lot more sensitive and can be a lot more critical of low level distortions than loudspeakers.
However if you still want to use it, here's how.
Realise that 3W is waaay more power than you need for headphones - so is 0.375W. I'd go further and say that these power levels can be dangerous. 115dBa through speakers is wall-shakingly, cup-sliding-off-table, stomach-hittingly loud. Loud.
The same level - measured with B&K SPL measuring apparatus) from headphones - without all these other cues - sounds ... well, a little bit loud. And that's probably under 0.1W with many headphones.
In either case, the Health&Safety Executive (UK) recommendation of 90dBa safe exposure over an 8 hour working day, to protect your hearing, translates to listening to 115dBa for ...
nearly 4 minutes.
Without all the other cues, headphones can leave you quite unaware of the danger. The fact they go so loud and stay clean and undistorted doesn't help.
(Still, the rock radio studio techs wanted them LOUDER!)
So it's OK to use this amp below its full power rating.
Now - the PAM8403 datasheet doesn't say what's actually inside it, but it's a reasonably safe bet that it's a full bridge for each channel. As Out_L+ is driven positive, OUT_L- is driven negative, and so on, giving you twice the voltage and 4x the power that a half-bridge will do. (With no input signal, both outputs will sit at half the supply rail ... check this with a meter).
So I would simply ignore OUT_L- and use OUT_L+ as a half-bridge (a normal push-pull amplifier). You will need to AC couple the output via 10uF (maybe 47uF would extend the bass a little) but then you can simply return the common GND from your headphones to GND.
It can't damage the amplifier and if you have all the bits it costs nothing to try.
  • \$\begingroup\$ Yeah I assumed it was a full H-Bridge too but couldn't get my head around connecting the two together, your solution is quite elegant. This is a pretty good idea, I'm keen to give it a go! Thanks for the help \$\endgroup\$
    – ALM865
    Jan 18, 2015 at 23:10
  • \$\begingroup\$ I have some doubts on this, with a class-d you cannot connect the two grounds and what you actually doing here is connecting the two grounds, the ground of the left and right channel on the amplifier output! I measured 12mV and 1.7mA between these ground leads without any load. I don't think this is a good idea. \$\endgroup\$
    – Codebeat
    May 9, 2018 at 23:24
  • \$\begingroup\$ @Codebeat What "two grounds"? Out_L- and Out_R- aren't grounds - and they aren't connected - they are simply left open circuit here. The "Ground" shown above is the actual ground pin. \$\endgroup\$ May 10, 2018 at 6:47
  • \$\begingroup\$ @BrianDrummond : OK, I didn't read the long "story", sorry about the confusion. \$\endgroup\$
    – Codebeat
    May 10, 2018 at 10:59
  • \$\begingroup\$ @ALM865 did you try Brian's suggestion ? It seems to be theoretically clean, elegant - something that should work. I'm just about to go out of my way to procure one of these PAM8304 modules for a quick headphone amp that I need to make. \$\endgroup\$
    – bdutta74
    Dec 26, 2018 at 8:36
An alternatative plan would be to place some sort of protection or load on the amplifier. Connect the positive outputs to the left and right headphone and place a four ohm resistor in series with a capacitor (around 200uf) for each channel. The four ohm resistor will limit the current coming out of the negative output and the capacitor will remove any dc component. I haven't tried this but it should work. You may need to experiment with the capacitor value so you have good low frequency response. A 47uf cap may do the job, but I don't know.
  • \$\begingroup\$ I made this however replace the 4 ohm resistors with 100 ohm resistors. I discover some heat development and to reduce the power of the output a little more. It is working fine however it requires some precautions. You need a very clean power source and you need to add some pull-down resistors (I used 20K) on the input. Still, it is not ideal, sound quality is decent however, depends on how the source is connected (can introduce noise) and the output can still sounds too hot at some levels. It works however the PAM8403 (board) is not a great candidate to use for this, so better don't try it \$\endgroup\$
    – Codebeat
    May 9, 2018 at 23:51
people. I used the PAM8403 with phones using this circuit:
Phones amplifier
Regards Sergio
  • \$\begingroup\$ Hello Sergio -- Thank you for this answer. What is the total mW output? Or the proper calculation? \$\endgroup\$
    – Nicholas
    Feb 13 at 17:11
