If we have a circuit like this: Circuit How can we make a good algebraic expression of the transfer function? I tried to go step by step with circuit analysis and then write expressions for each part of the circuit by itself but then I get an extremely long and complicated algebraic expression that is impossible to work with.
How can we get an expression that is written in the standardized form? Like this: Equation
Where \$H(s)=\frac{v_L}{v_i}\$
\$s = j \omega \$
\$n_1, ... ,n_m\$ are zeros and
\$p_1, ... ,p_n\$ are poles.
Once you find \$\dfrac{v_L}{v_1}\$, then just rearranging the terms will give you the standard form. Let me do this example for you.
Step 1: Calculate \$\dfrac{v_L}{v_1}\$
From the circuit, the following three equations can be derived directly. $$v_L = k_3v_3 \frac{R_L}{R_L + R_{s3}} \tag{1}$$ $$v_3 = -g_{m2}v_2(r_{\pi3}||\dfrac{1}{sc_{\pi3}})\tag{2}$$ $$v_2 = -(g_{m2}v_2 - g_{m1}v_1)(r_{\pi2}||\dfrac{1}{sc_{\pi2}})\tag{3.a}$$ $$ \Rightarrow v_2 = \frac{g_{m1}v_1(r_{\pi2}||\dfrac{1}{sc_{\pi2}})}{1+g_{m2}(r_{\pi2}||\dfrac{1}{sc_{\pi2}})}\tag3$$
Step 2: Rearrange the terms
Now from equation (1), (2) and (3), the value of \$v_L\$ can be expressed in terms of \$v_1\$. From this \$\dfrac{v_L}{v_1}\$ can be calculated. The answer will be in the following form:
$$\frac{v_L}{v_1} = K_1 \times \frac{r_{\pi3}}{1+sc_{\pi3}r_{\pi3}}\times \frac{r_{\pi2}}{1+sc_{\pi2}r_{\pi2}+g_{m2}r_{\pi2}}\tag4$$ where $$K_1= -g_{m1}g_{m2}k_3v_3 \frac{R_L}{R_L + R_{s3}}$$
Now its just a matter of rearranging the terms to convert it into standard form. Dividing numerator and denominator of equation (4) by \$(1+g_{m2}r_{\pi2})\$, $$\Rightarrow \frac{v_L}{v_1} = K_1 \times \frac{r_{\pi3}}{1+sc_{\pi3}r_{\pi3}}\times \frac{\frac{r_{\pi2}}{(1+g_{m2}r_{\pi2})}}{1+s\frac{c_{\pi2}r_{\pi2}}{(1+g_{m2}r_{\pi2})}}$$
$$\Rightarrow \frac{v_L}{v_1} = K \times \frac{1}{1+sc_{\pi3}r_{\pi3}}\times \frac{1}{1+s\frac{c_{\pi2}r_{\pi2}}{(1+g_{m2}r_{\pi2})}}\tag5$$ where $$K = K_1 \times r_{\pi3} \times \frac{r_{\pi2}}{(1+g_{m2}r_{\pi2})}$$
Now equation (5) is in standard form and value of poles can be calculated directly.
  • \$\begingroup\$ @Data \$v_2\$ is the voltage across parallel combination of \$r_{\pi2}\$ and \$c_{\pi2}\$. So \$v_2\$ will be impedance offered by this parallel combination \$\times\$ current through it. From nodal equation, current is the difference between those two current sources (\$g_{m2}v_2-g_{m1}v_1\$). The \$-\$ve sign is because of the polarity of \$v_2\$. The impedance is the remaining part in the expression (3.a). Eqn (3) is obtained by rearranging eqn (3.a) \$\endgroup\$
    – nidhin
    Jan 19, 2015 at 13:07
