Considering variable a and b as STD_LOGIC_VECTOR (31 DOWNTO 0) we have a + b as 33 bit result;
How can we get 32 bits out of this?
Does VHDL have something like (a+b)(31 downto 0) or we should store c:= a+b and then get c(31 downto 0)?
    \$\begingroup\$ Are a and b representing signed or unsigned numbers? This is why I don't use slv for arithmetic... \$\endgroup\$ Commented Jan 21, 2015 at 16:53
  • \$\begingroup\$ they seem to be unsigned, since i did not use signed library. \$\endgroup\$
    – VSB
    Commented Jan 21, 2015 at 17:23
  • \$\begingroup\$ It's not recommended to perform arithmetic calculations on STD_LOGIC types. Please use ieee.numeric_std and cast all your operands to SIGNED or UNSIGNED signals with the appropriate length. VHDL does not increase vector sizes to capture potential overflows. If you need \$C_{out}\$ then expand a and b to 33 bits by concatenation or by using the resize function. \$\endgroup\$
    – Paebbels
    Commented Jan 21, 2015 at 18:15
  • \$\begingroup\$ You don't specify which package."+" you use to produce a result with length 33. \$\endgroup\$
    – user8352
    Commented Jan 21, 2015 at 23:21
  • \$\begingroup\$ @VSB - if you don't use a library they are not anything. They are just a bag of bits. VHDL is strongly typed. If you mean something to represnt a number, please use the perfectly good types available for that. Either integer int he basic language or the unsigned and signed vectors from ieee.numeric_std. parallelpoints.com/numbers-in-vhdl \$\endgroup\$ Commented Jan 22, 2015 at 8:31
If a, b, c are of type std_logic_vector(31 downto 0),
then, c := a + b;
will give the 32 bit answer in c (without carry) as you required.
If you want 33 bit answer in c (where c is std_logic_vector(32 downto 0))
Then c := ('0' & a) + ('0' & b) will give the 33 bit answer.
But you will need ieee.std_logic_unsigned package for adding std_logic_vector using + operator.
  • \$\begingroup\$ Interesting. Personally I'd like to hear why and how this works :) \$\endgroup\$
    – Dzarda
    Commented Jan 21, 2015 at 14:59
  • \$\begingroup\$ I think a misunderstanding happend. A(32)+B(32) --> OUT(33) this is due to carry out of add operation, and I want OUT[31..0]. \$\endgroup\$
    – VSB
    Commented Jan 21, 2015 at 15:11
  • \$\begingroup\$ @VSB Sorry about the misunderstanding. :) \$\endgroup\$
    – nidhin
    Commented Jan 21, 2015 at 15:54
declare
signal temp : std_logic_vector(32 downto 0);
and in code
temp <= ('0' & a) + ('0' & b);
c <= temp(31 downto 0);
From what I understood from your question this answer will help you. Else let me know.
  • \$\begingroup\$ I want to know is it possible to this without temp variable, somehow? \$\endgroup\$
    – VSB
    Commented Jan 22, 2015 at 17:34
    \$\begingroup\$ With any conventional package, temp <= a + b won't compile. Neither the operators in the non-standard std_logic_unsigned package nor those in the standard numeric_std_unsigned produce an output that is automatically 1 bit larger. \$\endgroup\$
    – fru1tbat
    Commented Jan 23, 2015 at 13:21
  • \$\begingroup\$ @fru1tbat yes you are right. Made changes. Now it is correct right? \$\endgroup\$ Commented Jan 23, 2015 at 15:45
