-1
Looking to scavenge a tmp36 off of some fried electronics, would anybody have any leads on where to look for this type of sensor. I normally wouldn't mind to buy one, but I live in a pretty remote part of the world and don't really want to order one in. Recommendations for any Arduino compatible sensor would be good as well.
closed as off-topic by Leon Heller, Ricardo, PeterJ, Daniel Grillo, Michael Karas Jan 22 '15 at 13:12
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
If you are remote you can use a diode as a temperature sensor. ~2mV/C, you'd have to calibrate it yourself. Drive it with a current source ~10uA and read the voltage. I guess you might want a bit of gain to get the voltage up to what the aruino wants. (Does it have a low voltage ADC?)
  • \$\begingroup\$ The arduino apparently reads everything in 5V'ish, but some articles that I have read point to deviations in what this number actually is, notably: hacking.majenko.co.uk/making-accurate-adc-readings-on-arduino I'm a bit of a noobie when it comes to this stuff, but looking to do a project with temperature sensors and set up a database to record them in. \$\endgroup\$ – ParanoidPenguin Jan 21 '15 at 21:08
  • \$\begingroup\$ OK If you know about opamps and gain, then the diode would be OK. Otherwise it's perhaps best to stick with a sensor that outputs a voltage in the range of your ADC. There are a lot of IC temperature sensors.. I've never used them, try searching on digikey. \$\endgroup\$ – George Herold Jan 21 '15 at 21:19
