I'm currently trying to get the comparator on dsPIC33EP256GP502 works, but get stuck in the comparator interrupt. Basically what i want to do is just using the comparator to compare two external voltage inputs, and generate the interrupt upon the low-to-high transition of the comparator output is detect, but the program has never enter the ISR in the test.
i have tried to manually set the interrupt flag(IFS1bits.CMIF) to 1 in the main loop, then the interrupt has been successfully triggered, and entered the ISR, and in the ISR i have tested, the below interrupt condition is fulfilled:
CMSTATbits.C1EVT = 1 and CMSTATbits.C1OUT = 1
I just don't know why the interrupt cannot be triggered automatically when the preconditions are fulfilled, maybe there are some setting errors ?
I really need suggestions and instruction as i have already wasted so much time on this issue.
Any suggestions are greatly appreciated, and thanks in advance.
I paste my code for setting the comparator below:
// comparator 1 input pin set
ANSELBbits.ANSB2 = 1; // C1IN1+ ANALOG
TRISBbits.TRISB2 = 1; // C1IN1+ INPUT
ANSELBbits.ANSB3 = 1; // C1IN1- ANALOG
TRISBbits.TRISB3 = 1; // C1IN1- INPUT
// COMPARATOR 1
CM1CONbits.COE = 0; // comparator output is internal only
CM1CONbits.CPOL = 1; // comparator output is inverted
CM1CONbits.OPMODE = 0; // Op Amp is disabled
CM1CONbits.CEVT = 0; // clear comparator event bit
CM1CONbits.COUT = 0; // initially the Vin+ > Vin-
CM1CONbits.EVPOL = 0b01; // interrupt is generated only on low-to-high transition of the comparator output
CM1CONbits.CREF = 0; // VIN+ input connects to C1IN1+
CM1CONbits.CCH = 0b00; // select VIN- input connects to C1IN1-
CM1CONbits.CON = 1; // enable comparator 1
CM1FLTRbits.CFLTREN = 0; // disablt the digital filter
CMSTATbits.PSIDL = 0; // continues operation of all comparators in idle mode
IPC4bits.CMIP = 4; // set interrupt priority to 4
IFS1bits.CMIF = 0; // clear the intrrupt flag
IEC1bits.CMIE = 1; // Enable the interrupt
INTCON2bits.GIE = 1 // Enable the global interrupt
// ISR
void __attribute__((interrupt,no_auto_psv)) _CM1Interrupt(void)
IFS1bits.CMIF = 0;
// IF INTERRUPT FROM CM1
if(CMSTATbits.C1EVT && CMSTATbits.C1OUT)
// Turn off the valve1 PWM output
set_valve_channel_one_pwm_off();
