This code is from asic-world:
module decoder_using_assign (
 binary_in   , //  4 bit binary input
 decoder_out , //  16-bit out
 enable        //  Enable for the decoder
  input [3:0] binary_in  ;
  input  enable ;
  output [15:0] decoder_out ;
  wire [15:0] decoder_out ;
  assign decoder_out = (enable) ? (1 << binary_in) : 16'b0 ;
endmodule
I can't seem to wrap my head around (1 < < binary_in). binary_in is 4 bits wide, how is the logical left shift producing an output 16 bits wide when enable is true?
binary_in is 4 bits, so can hold a decimal value anywhere in the range 0-15.
If you left shift 1 by between 0 and 15, you get a number with at most 16 bits.
16'b0000000000000001 << 0 = 16'b0000000000000001
16'b0000000000000001 << 1 = 16'b0000000000000010
16'b0000000000000001 << 2 = 16'b0000000000000100
16'b0000000000000001 << 15 = 16'b1000000000000000
