What kind of socket would I use to connect a 5-pin 0.067" pitch part (the Murata OKR-T10-W12) to a piece of normal 0.1" pitch stripboard?
Googling "0.067 5-pin socket" gets me hits for CPU sockets and the like.
  • \$\begingroup\$ Those aren't usually intended for a socket. \$\endgroup\$ Commented Jan 25, 2015 at 19:54
  • \$\begingroup\$ Try CAPITAL ADVANCED 33115 SMD ADAPTER, 5-TO-263, 5-SIP -- adapter board intended for 1.7mm pitch SMT component to 2.54mm (0.100 inch), won't be pretty but might work for this application. The only 1.7mm adapter I found on newark/element14. \$\endgroup\$
    – MarkU
    Commented Jan 25, 2015 at 21:06
  • \$\begingroup\$ @IgnacioVazquez-Abrams What are they intended for in that case? To be directly soldered onto a board? I wanted to avoid soldering them directly to make them more easily replaceable, and less easily damage-able during the process. \$\endgroup\$ Commented Jan 26, 2015 at 8:58
You could make a breakout PCB using Mill-Max female pins and a 0.1" pitch header. Photo (rendering, actually) is from Digikey, Mill-Max 0507-0-15-15-31-27-10-0.
Or if you're in a hurry, just solder some bare extension wires on and stick them in the breadboard (staggered).
  • \$\begingroup\$ Soldering the pins bare was something I was trying to avoid, as above. \$\endgroup\$ Commented Jan 26, 2015 at 8:59
