I am getting ab + bc'd' + ab'c', But I keep failing, it doesn't work for my table.
Can someone explain to me what am I doing wrong? This is using minterms.
There is firstly a mistake, it is not \$ab'c'\$ but \$ab'c\$. And you also have to keep in mind that the table rolls in the edges (both left/right AND bottom/top), so that the two lower 1's can be grouped with the two upper 1's. The last term \$ab'c\$ can then be further reduced to \$ac\$. Finally you forgot one 1 alone, which is \$a'b'c'd\$.
The four end corners combine to give 'ac'.
The upper four(ab) and the duplet(bc'd') are correct in yours. All 1's are covered. Hence =ab+ac+bc'd'
