And I have forklift battery 24V which is almost at the end of life. The 24V charger is very strong and heat battery and not working properly. I have one 12V battery charger, which works very fine.
24v Lead acid battery has 12 cells in series. And I can read 12V on first 6 cells. It is safe to charge this first 6 cells and after then rest six cells with 12V charger?
Thanks
Yes, you can charge half the battery and later charge the other half. But a better alternative might be to look for a method to reduce the charge rate of the 24V charger. putting a resistor in series with its output could be one way to do that. Perhaps a coil of steel wire.
