We are designing a board around Atmel SAM4E microcontroller, and use Atmel-ICE for debugging/programming. To save space, we would like to avoid including the whole ICE connector. Which are the minimum set of required pins so that I can still program and debug over SWD?
Atmel shares JTAG and SWD pins on their ICs. The SAM4E datasheet says it clearly:
SWD & JTAG pins sharing
SWD is (in most cases) a two-wire interface, so the only program/debug connection is TMS/SWDIO and TCK/SWDCLK.
  • \$\begingroup\$ Will a three wire interface (SWDIO/SWCLK/GND) allow programming the internal flash as well? \$\endgroup\$ – Atilla Filiz Jan 27 '15 at 16:02
    \$\begingroup\$ @AtillaFiliz We don't count GND as a signal wire. But yeah. \$\endgroup\$ – Dzarda Jan 27 '15 at 17:09
